R-D cross bar help...
Old Jul 12, 2006 | 06:23 PM
DieL's Avatar
DieL
Default R-D cross bar help...
have a question about the cross bar camera mount. Its been weeks since r-d has emailed back so i couldn't find out there. What size/thread are the 2 bolts that screw the camera mount plate into the bar?
thanks
Old Jul 12, 2006 | 06:39 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I had a camera mount with my cross bar but never installed it. It's all gone now since I installed a roll bar but I'd guess they'd either be 5/16" or 3/8" NC.
Old Jul 13, 2006 | 05:12 PM
Slalom4me's Avatar
Slalom4me
Did you find an answer? If not, I'll check and post.
Old Jul 19, 2006 | 02:26 AM
DieL's Avatar
DieL
nope I did have the bar powdercoated so it might be why i can't easily thread any screws in. I wanted to make sure before i try to force the wrong size in and strip the threads
Old Jul 20, 2006 | 01:33 AM
Slalom4me's Avatar
Slalom4me
For my '89, the bolts for the camera mount on the
R-D Cross-Bar are 5/16 dia NC x 3/4" (1/2" hex head)
My vote - do not force a bolt into coated threads.
Get the proper tap size and chase the threads.
I recommend a Bottoming Tap (a different taper on
the end - you don't need the style used for cutting
new threads, you want to get full thread for as
much of what you can reach.)
If you haven't done this before, one proceedure is
to get the tap started and then turn 3/4 in, followed
by 1/4 turn back out. Repeat until the tap reaches
the end of the blind hole. This procedure allows
the cuttings to drop out into the flutes.
A proper tap holder will ake the job easier.
To R-D cross bar help...
