From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
You'll have to remove your starter too if it's like mine. It doesn't slide over the starter but instead the nose of the starter goes through a hole in the cover. You will have to finaggle the cover past the transmission cooler lines too. You can leave the wires on the starter if it'll leave you enough room to get it out of the way. But unhook the battery or be careful not to ground the hot cable.
Thanks, I will look closer. However I do have some oil on the starter side. I don't think its the intake but I will know more when I get it cleaned up.
