Gen 7 & closed loop corection
Old Jul 9, 2006 | 11:39 AM
Schurters Blowen LT's Avatar
Schurters Blowen LT
Default Gen 7 & closed loop corection
Is there any why to set this up to stay on longer ?
Old Jul 9, 2006 | 12:41 PM
DieL's Avatar
DieL
Once you hit closed loop.. it should stay there. Mine does. Explain what is happening ?
Old Jul 9, 2006 | 01:05 PM
Schurters Blowen LT
It go's into closed loop and it will do it thing but after a min it stops it stays at zero and will not move .......i no the tune is out 5-10%...i can't fig it out on how to make it stay on all the time....
Old Jul 9, 2006 | 06:39 PM
DieL's Avatar
DieL
what kind of a sensor are you using? heated o2 or wideband ? is it turning off after driving? if so where in the collector is it located ?
Old Jul 9, 2006 | 07:29 PM
Schurters Blowen LT
I have the LM-1 wb02 sensor, wired into the gen 7, i have jethot LT headers and the sensor is in the collector pipe where you would have your reg 02 sensor
Old Jul 9, 2006 | 07:41 PM
DieL's Avatar
DieL
Is your dfi showing a code at that time that the #s were out of range for too long or something along those lines? I do know when i had the wideband in and i forgot to switch the uego sensor type to #2 mine would stop working. Perhaps you have the setting on the wrong one ?
Old Jul 9, 2006 | 07:45 PM
Schurters Blowen LT
No there is no codes.
i have it set up in the DFI hego/wb02 sensor
generic 0v-10afr 5v-20afr
from what i see it is all set up right, and it dose work it is just the time it stay on is way to short ....to fully tune the car
Old Jul 9, 2006 | 08:34 PM
DieL's Avatar
DieL
I don't know what the LM-1 requires for the gen 7 to read it correct. I was going to go that route but accel came out with the analyzer/wideband. I didn't know the Hego can be configured to work with a wideband. Im not very experience with this so don't take me for an expert... just trying to help I do know the analyzer i have needs to be on uego setting type 2. I know type 2 reads the 0-5v wideband. From what i thought i knew, the LM-1 outputs are 0-5v too.
I was going to get a LM-1 setup from TJWong. try Pm'ing him or giving him a call I'm sure he can set you in the right direction.
Old Jul 9, 2006 | 08:36 PM
Schurters Blowen LT
What did you pay for the analyzer/wideband and where did you get it ?
Old Jul 13, 2006 | 04:25 PM
DieL's Avatar
DieL
I paid $495 + shipping for mine. Accidentally I got stuck with 2 because the shoppe ordered one as well. SO if you're interested in the setup I have one new in the box for $475. I forgot the part # but i can get it if you're interested.
Old Jul 13, 2006 | 07:07 PM
Schurters Blowen LT
If you can get all the info you can and pic ..that would be cool...and if it what i need i can pick it up this weekend....
thanks
Jeremy
To Gen 7 & closed loop corection
