Dissapointment on the Dyno
I got an email back from Bryan reference the tune. He looked at the dyno info and wideband 02 info and said it is lean. He will add fuel and expects that to bring it up 5-10 hp. Also Bryan said they stopped the pull while the engine was still producing power.
The dyno results were SAE corrected and it was a dynojet.
Will post a link to the dyno info later when I have more time.
The car is a 94 auto, the AC and ASR were turned off.
I guess after I install new fuel injectors and get the corrected tune I will see how things are going, and make another pull. Will also look into the cam install and be sure it is correct.
prattman
Something about his combo is messing him up...but (again) not as much as he thinks.
I'm thinking he is only down about 20hp....? A tired motor could cost that much....
Larry
code5coupe
There are some pics of the heads in the link below' about halfway through the post.
We had this discussion a long time ago about polishing the intake ports on the heads. At the time we discussed it the heads were already polished and installed on the engine. Your advice from a while back may we be good advice and this may be something that is hurting my performance.
Thanks for you comments.
prattman
http://forums.corvetteforum.com/show...post1555429950
Larry
code5coupe
My original post says, I was expecting 320 rwhp or more.
I don't think I am trying to make out as though I should have really high HP numbers as this engine project was a lot of compromises. It is my daily driver so I wanted good manners and driveability so I knew I would not be producing high HP numbers.
It is the missing 20 HP I am tring to find.
Thanks for your comments, I respect the opinions of everyone on the forum.
prattman
prattman[/QUOTE
Does the car have headers on it?
Biography:
GM Hotcam
Cloyes double roller iming gear set
1.6 Crane Gold Race roller rockers
EM long tube headers (ceramic coated inside and out)
CSR electric water pump
Stock LT1 aluminum heads ported & polished
Comp Cams (26915) Beehive valve springs/retainers
Cut-back valves and 3 angle valve job (stock valves)
ATI SFI rated balancer
MSD Superconductor plug wires (red)
Upgraded to 95 timinig cover and vented optispark
EGR deleted
Air Injection deleted
NGK Iridium Spark Plugs
Cats Eliminated
I’d make a guess anywhere from 310 rwhp to 320 rwhp as the heads are a matter subject to some objective testing on a flow bench to see if you got anything out of them.
The best thing is post the entire dyno sheet so everyone has a little more to look at and scan the engine to make sure your not having some other problems. If you haven’t replaced the 02 sensors in a while I’d strongly suggest you do so as it’s amazing how much better a car runs with fresh 02 sensors. Always use stock 02's and not some aftermarket replacement. The GM computer is programmed to see GM 02sensors and they always work the best.
Also check your MAF to see if oil from something like a K+N filter is on the wires. That can throw off your fuel/air and kill power.
Not a fan of mail order tunes either. I’ve seen some dead on the money and others out in left field.
You may not be all that far off and a matter of just correcting a couple of minor issues. Most people fall short of their cars potential just because it not in perfect state of operation. The car needs to be 100% to be 100%.
prattman
Here is a picture of my heads after they were ported by the same guy that ports Winston cup heads for factory Chevy teams (my heads are on top, factory LT4 heas are on the bottom);
You can see the slight, even roughness to the intake ports.
The exhaust ports can be, and should be polished though, that's perfectly fine. As much as this sucks to hear if I was in your posistion I would take the heads off and carefully rough up the intake ports to remove the polished finish.
EDIT; Holy crap my spelling sucks...long day
This guy is some kind of head guru at some school. No bashing me please because I don't keep up on who's who in the performance engine game.
These are prattman's intake ports...
mirror finish is not hurting him here at all... I always mirror finish intake ports on manifolds and heads and have some of the highest power numbers for the cams used on production LT1/4 cylinder heads, so that is a complete falsified myth for fuel injected motors where the injector has atomized the majority of the fuel while spraying under pressure. (if it were true direct injected engines would suffer from no atomization due to the injectors firing into the chamber directly on the compression stroke never seeing a port. it is a TRUTH for carbed motors where fuel comes out in droplets from the venturis and rely on turbulance in the following intake track to atomize the droplets by the time they reach the combustion chamber for a more uniformed mixture. I have been porting LT1/4 cylinder heads for a decade now with absolute disgust for the claims made by CNC ported heads stating that they create a "cushion of air" what they are doing in all actuality as seen by using smoked air is making a smaller port by increasing turbulance and making the runner smaller in terms of flow path. even at a mirror finish there is going to be some turbulance but much closer to the port wall which does not disrupt the flow characteristic of the port nearly as much as a rough finish or a CNC machine tool path. if the ribbed or rough finish were such a benefit to reducing resistance of airflow, jets would utilize this technology.. when is the last time you saw a rough finished jet fusalage? or cars which are designed to reduce wind resistance for top speed? the claims made were to reel in buyers and give them a warm fuzzy feeling while the truth of the matter is that the companies using CNC machines would have to invest more time per head to reduce the tool path ridges or make closer passes with the cutting bit. both of which require more time, more finite programming and in the end will reduce production and increase cost hurting the bottom line.
if you want to argue this point you are more then welcome, but if you would like to pull out dyno graphs and compare power made with several different cams... you better have some really impressive data.
an example of some of the port finishes used on prodcution untouched shortblocks with hot cams, GTP6 cam, 847 cam, 219 lingenfelter cam.. were all well well above the average seen by many on here. to date I know of one person using the hot cam that was able to beat out the numbers made with the hot cam and that was done using a 1.7 ratio rocker arm which took advantage of the flow at higher lift. pictures will be below.
on to the car in question.. something is off.. a bone stock hot cammed LT1 with nothing else done would be above 300rwhp even with stock manifolds and cats. if the dyno oerator shut the run down before it was through making power, it would make some difference, but not 30rwhp over 5-600 RPM in the end. the ports in the pictures don't look bad and would not contribute to the end result being as poor as it is. soemone nailed it in my opinion.. check for being a tooth off with the timing set. if it is an adjustable timing set check to make sure the crank sprocket is NOT on an advanced or retarded keyway, the hot cam has 4 degrees of advance preground into it and should be installed straight up with zero change of the base keyway location for maximum all around performance. also check to make sure your install height on the springs is correct, it should be fine considering the springs you are using, but checking never hurt. rocker arm adjustment.. if you used the spin method your rocker arms are way overtight. adjustment from zero lash is in terms of vertical movement the second they do not move up and down between the lifter and rocker arm is zero lash.. tighten 1/4 turn past this and lock the allen screw down.
make sure your fuel filter is clean and flowing well, make sure pump is not tired, make sure injectors are CLEAN or replace old and tired injectors. make sure your not seeing knock retard from noisy valve train and if you are and your timing is retarding excessively this will severely hurt performance. if the engine was rebuilt.. what is the calculated static compression ratio of the engine with the heads used? was a compression and leak down test performed to ensure the machine work was done correctly and there is not excessive piston to cylinder wall clearance or excessive ring end gap? is there crank case pressure at WOT? can you post the dyno graph with Air Fuel Ratio for us to review. did you get a log of the ECM while running the dyno pulls? go into as much detail of the build as possible to help us track down possible causes for the low numbers your experiencing.
Chris
I couldn't have said it better, thank you.
I have been of the opinion that mirror polishing the intake ports HAS to produce better flow. As your aircraft surfaces analogy illustrates.
I spent many many hours polishing the intakes, and if I didn't think it would help, I would not have done it.
So far you and I are the only two that think the same way on this subject.
went to the 1/8th mile strip last night, only got two runs in before it rained. Both of the runs were bad 9.7 sec best, but it was me and not the car.
I was on street tires and spun alot, and my reaction times and 0-60ft are pretty bad. This is not a suprise as it was the first time I ever ran on a drag strip. Was a lot of fun and I will work on technique this summer.
I will get busy and post the dyno/air fuel stuf in a few minutes, i have been away from home all day.
I will get busy with checking fuel pressure, and I am not sure how to check the cam install, I will need to think about that.
To all that have responded, thanks, I do alue everyone's opinion, and I will get some more nfo up on this thread.
Thanks,
prattman
Oh, I lost the race by.9 sec. It was me and not the car.
http://i58.photobucket.com/albums/g2...s/Dynopull.jpg
I also have a TTS datamaster scan I can email to anyone that woud like to see what else is happening.
Oh, the O2 sensors are new, and they are GM parts
.....go into as much detail of the build as possible to help us track down possible causes for the low numbers your experiencing.
Chris
QUOTE]
Chris,
It is a 94 LT1 4 bolt main out of another 94 vette.
I checked all of the specs per the FSM, and had the machine shop bore gage the cylinders. They recommended hone and new standard size cast rings which is what I did. Ring gaps were checked/installed per instructions provided and the FSM.
Main and rod journals were within specs per FSM, so I installed new standard size bearings and new cam bearings. New Cloyes bouble roller timing set and did the opti conversion to the 95 cover and vented opti.
Bottom end is stock, top end got the Hot Cam.
I posted all of this a long time ago and I could dig the links to them up if needed.
prattman
As soon s I can figure out th best way to check it I will. Do you have any suggestions?
Thanks,
prattman
