Dissapointment on the Dyno
Old Jul 13, 2006 | 05:59 PM
prattman's Avatar
prattman
Default Dissapointment on the Dyno
Went to the Dyno Wednesday, I built an LT1 350 last year and put it in the 94 vette a few weeks ago.
Only made 297 RWHP 301 TQ on the dynojet.
It was 99 degrees and the humidity was high so it wasn't the best time to do it.
I was expecting 320 RWHP or more, but that just didn't happen.
I sent the dyno info and fuel air info to Bryan Herter and I have not heard from him yet, maybe he can squeeze some more out of it.
I didn't replace the fuel injectors yet, they have close to 190K miles on them, so maybe that will help some.
Mods are listed in my sig.
Tomorrow I am running a guy at work with his 02 Trans AM, WS6, at our 1/8th mile strip.
I bet I am going to be dissapointed again....
prattman
Old Jul 13, 2006 | 06:27 PM
honda hunter's Avatar
honda hunter
Is this corrected or un-corrected?
Old Jul 13, 2006 | 06:38 PM
TankerVette's Avatar
TankerVette
umm... can you tell us a little about the motor (cam, heads, exhaust)? 300 isn't bad if it wasn't modified much...
Old Jul 13, 2006 | 06:49 PM
ANTI VENOM's Avatar
ANTI VENOM
If it was uncorrected, it may not be as bad as it seems. Is this a stick or an auto? Heads also make all the difference. Do you have flow #'s from the port job? Was the AC still on? Good luck with the race.
Old Jul 13, 2006 | 06:55 PM
Great White North's Avatar
Great White North
Good luck!!Maybe you will be suprised!!
Old Jul 13, 2006 | 07:06 PM
STL94LT1's Avatar
STL94LT1
I just checked your mods. Those numbers are really low. Who ported the heads?
Old Jul 13, 2006 | 07:30 PM
Zix's Avatar
Zix
Dynojet or Mustang dyno? Do you have a dyno-sheet you could post up? What were the air/fuel ratios?
There should be a lot more in it, something's not right!
Old Jul 13, 2006 | 07:33 PM
88BlackZ-51's Avatar
88BlackZ-51
prattman
hmm, about the same #'s as a stock LS1. u should take the WS6 if he is stock.
Old Jul 14, 2006 | 01:22 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Something serously doesn't add up..
Does the car have headers on it?
Old Jul 14, 2006 | 01:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
Biography:
GM Hotcam
Cloyes double roller iming gear set
1.6 Crane Gold Race roller rockers
EM long tube headers (ceramic coated inside and out)
CSR electric water pump
Stock LT1 aluminum heads ported & polished
Comp Cams (26915) Beehive valve springs/retainers
Cut-back valves and 3 angle valve job (stock valves)
ATI SFI rated balancer
MSD Superconductor plug wires (red)
Upgraded to 95 timinig cover and vented optispark
EGR deleted
Air Injection deleted
NGK Iridium Spark Plugs
Cats Eliminate
Old Jul 14, 2006 | 05:35 AM
93 ragtop's Avatar
93 ragtop
Well I am going to take a stab in the dark on this one, but something is way off, assuming this is a dynojet and the nos. are corrected. After checking the things such as tune, etc, you may want to double check the cam was installed correctly and not 1 tooth off. There has been a few post on here of people doing that and the power drops are like yours. The other thing is who ported your heads? If someone who is not familiar with LT1-4 heads did the work, sometimes can do more damage then good. Also, did they install bigger valves? FWIW your mods and mine look to be about the same. See signature.
Old Jul 14, 2006 | 07:21 AM
prattman's Avatar
prattman
I ported the heads, the scope of the job was to remove all of the rough casting and polish like a mirror, on intake, exhaust ports and bowls. Valves are stock. Don't have flow numbers.
I got an email back from Bryan reference the tune. He looked at the dyno info and wideband 02 info and said it is lean. He will add fuel and expects that to bring it up 5-10 hp. Also Bryan said they stopped the pull while the engine was still producing power.
The dyno results were SAE corrected and it was a dynojet.
Will post a link to the dyno info later when I have more time.
The car is a 94 auto, the AC and ASR were turned off.
I guess after I install new fuel injectors and get the corrected tune I will see how things are going, and make another pull. Will also look into the cam install and be sure it is correct.
prattman
Old Jul 14, 2006 | 08:46 AM
MrNuke's Avatar
MrNuke
Yeah something's amiss here.. You should be in the upper 300RWHP range IMO..
Even IF you are lean and have a bad tune you should be higher.. Post your Dyno chart..
Old Jul 14, 2006 | 09:05 AM
ALLT4's Avatar
ALLT4
prattman
I don't think the intake is supposed to be polished to a mirror finish, makes for bad atomization of the fuel. I let mine rough but anything before the injector was polished. Now the exhaust I did polish to a mirror finish the whole way through.
I also let the intake port just shy of the OD of the gasket opening. Meaning it doesn't quite go to the scribe lines. I feel it makes a little anti-reversion wall. May do nothing but it's there and in theory it works.
Just some food for thought.
Old Jul 14, 2006 | 10:14 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Biography:
GM Hotcam
EGR deleted
Cats Eliminate
Basically, he picked up about 40hp on his LT1 with a cam, rockers, and headers, which has him not far off what some stock LT4's will pull.
Nothing else in the list adds significant torque/power.
The "porting" is just amateur polishing that could have hurt as much as helped.
Yes, he's low, but not by as much as he thinks.
Larry
code5coupe
Old Jul 14, 2006 | 10:25 AM
Aardwolf's Avatar
Aardwolf
There's some CFM's there though to.
Old Jul 14, 2006 | 11:36 AM
Wildcat1's Avatar
Wildcat1
I have stock untouched heads, cam, rr and I got 291rwhp and 326rwtq, so something is very wrong with this so far. My only hp mods are basically a TB and headers. You've seen my full list prattman, so you know what all I have. I'd like to see your dyno chart with a/f. The contact I gave you has taken a break from tuning I think, did you ever contact him? We may could round him up.....
To Dissapointment on the Dyno
Old Jul 14, 2006 | 11:43 AM
ol,RJ's Avatar
ol,RJ
190k on fuel injectors is alot of miles.
odd's are they are way past their prime, and may be the reason your lean.
I'd replace them and anything else on the fuel side (filter and pump) if the mileage is high on them. then head back to the dyno.
bet you pick up 30+ hp
Old Jul 14, 2006 | 11:44 AM
rocco16's Avatar
rocco16
You have stock heads, he has stock heads. (non-pro polishing is stock)
You have RR, he has RR.
You have a cam, he has a cam.
You have headers, he has headers.
You have TB, he has electric WP.
He makes six more hp.
He may be disappointed, but I'm saying he shouldn't be.
Larry
code5coupe
Old Jul 14, 2006 | 12:19 PM
Wildcat1's Avatar
Wildcat1
No, I have all stock components, he doesn't. That's my point. Something is way wrong.
