Simple C4 17X11 question
Jul 14, 2006 | 05:35 PM
I want to use 17x11 50mm offset rims on my C4 with 335/35/17 tires. How will it fit, will there be any drivability issues, will there be any rubbing?
You must provide the year of the car.
Jul 14, 2006 | 05:51 PM
I think he has a 94. It will stick out a bit from the fenders.
Jul 14, 2006 | 06:07 PM
Sorry about that. Yes it is a 1994. So the best route would be to go with 38mm's?
Jul 14, 2006 | 06:11 PM
No, you must use the 50mm offset.
But the 335 will stick out a bit.
Jul 14, 2006 | 06:19 PM
I dont know why I typed 335. I ment 315. So with 315/35's and a 50mm offset would I be good to go?
Jul 14, 2006 | 06:28 PM
I have 17x11's in the rear with 315mm tire......you'll be fine. They'll stick about 1/4" but it looks fine
Jul 14, 2006 | 06:32 PM
Quote:
What offset? 50mm?
Jul 14, 2006 | 07:57 PM
Yes its still going to stick out, this is why the GrandSport uses a Fender flare.
Jul 19, 2006 | 11:35 AM
Just a note, if car is lowered in rear you will rub innner fender liner with 315's if you drive hard.
Larry
Jul 19, 2006 | 11:46 AM
Seems like everyone says to get the GS flares if your tires stick out but that doesnt stop it from rubbing the fender still.
Jul 19, 2006 | 11:50 AM
In hard racing anything can happen, even moreso if you lower the rear.
Jul 19, 2006 | 07:33 PM
Quote:
Originally Posted by honda hunter
What offset? 50mm?
Yes 50mm. And no rubbing at all......and I'm lowered 1" all the way around
Jul 19, 2006 | 08:03 PM
St. Jude Donor '03 & '05
50mm offset, 315's 17x11's, doesnt stick out because I narrowed the brake bracket, used a 87 spindle etc etc. This modification brings the tires in an additional 13 mm as the 87 spindle is 13 mm shorter than a 93.
Jul 19, 2006 | 08:07 PM
Not to jack the post but can you run 11's up front? I have 4 17x11 50mm offset ZR1 wheels and was thinking about running 11's all around for auto-x but wasnt sure if i would have rubbing problems.
I have a 95 that is stock height. Thanks for any info
Jul 19, 2006 | 08:53 PM
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Quote:
Larry
slight correction, you will rub your tires at stock ride height with 285's if you drive hard, more so with the 315's.
Jul 19, 2006 | 09:36 PM
St. Jude '03 thru 14,'25
96 LT4 315/35's and a 50mm offset
Jul 20, 2006 | 05:35 AM
well here are my 17X11 335 TIRES
the did stick out but i solved that
old:
new:
painted:
Jul 20, 2006 | 07:15 AM
old:
new:
painted:
those are ZR1 wheels which is why.
Jul 20, 2006 | 09:02 AM
Quote:
and they look great
[at least i think so
