Change out OPTI?
Old Jul 16, 2006 | 03:50 AM
RetroTA's Avatar
RetroTA
Default Change out OPTI?
My 93 LT1 43,000mi. wont start! getting code 16 (OPTI low resolution) but im getting a constant strong spark at all cylinders? fuel pressure holds at 40 lbs for at least 20 minutes, ohmed all injectors (12.9 all), did "noid" test, changed: plugs, fuel filter, checked coil and all other wires, even syphoned and replaced the fuel, wont even fire with either shot into air intake. All voltage tests OK at the ICM socket and OPTI test socket. If OPTI's bad would I get good spark? Am I missing something? Im thinking about converting a new opti with a vacume system. Several web sites post the proceedure to modify 93-94 OPTI. it doesnt seem too difficult. Anyone had luck with this or should I go with MSD or Accel upgrade?
Old Jul 16, 2006 | 08:42 AM
sonomacrew01's Avatar
sonomacrew01
open the fuel rail cover and check the voltage on the red/black wire from the opti harness..
http://forums.corvetteforum.com/show....php?t=1426836
