HELP ENGINE -C4 L98 Stock
Old Jul 16, 2006 | 11:41 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default HELP ENGINE -C4 L98 Stock
Guys, Need some help here. (87/L98/Stock)
She starts right up, runs high idle, then slowly chokes out and dies. You can give her gas, and she will continue to run, with constant gas, but leave off the throttle and she chokes out and dies.
Pressure : 43psi @ rails and holds for 1hr+
Startup: Fires right up, no hesitation on startup
Battery: 12.2v costant
Codes: No error codes and no codes during scan while running.
Vacume Lines: all lines check and connected, no leaks, did leak testing
Any help would be appreciated.
thanks
vinnies87
Old Jul 16, 2006 | 11:45 AM
Bruce Witherspoon's Avatar
Bruce Witherspoon
thanks
vinnies87
Is the idle air controller coked up? Pull it out and see if it has carbon restricting its travel.
Old Jul 16, 2006 | 11:54 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I don't know if that battery reading is using a meter or off your dash display, but 12.2v at start-up is pretty low. If i remember correctly 12.9 is a fully charged battery. If it's the dash, mine reads about 14.2 at start-up and then drops back to 13.9 after running a while. I'm wondering if your alternator is going bad or there is a battery problem.
Old Jul 16, 2006 | 11:58 AM
vinnies87's Avatar
vinnies87
Battery and alt good, spent alot of time with ign on for testing.
Old Jul 16, 2006 | 11:59 AM
JackDidley's Avatar
JackDidley
Unplug the MAF and see what it does. Codes ??
Old Jul 16, 2006 | 12:45 PM
rick lambert's Avatar
rick lambert
As clean as you keep your vette, I suppose the fuel filter is OK? More than likely the IAC, and if it's carboned up it probably won't show on the scanner..
Old Jul 16, 2006 | 12:56 PM
vinnies87's Avatar
vinnies87
Rick:
thanks, have a new iac here, and am just in the process of replacing and setting. Don't think its the filter or pump at this point. Gonna replace the IAC and set IAC & TPS again. TPS shows on the scanner @ 5.5, so it looks good. Thanks, for the words of support.
Old Jul 16, 2006 | 01:00 PM
CFI-EFI's Avatar
CFI-EFI
If the IAC passages have a blockage, the scanner should show the IAC counts through the roof as the ECM attempts to get air in there to maintain an idle.
RACE ON!!!
Old Jul 16, 2006 | 01:03 PM
rick lambert
Exactly what I'd do, it's probably pretty well carboned, just make sure you clean the passages. I don't know why guys just clean the pintle and passages and call it a day, these only cost about $30, new stepper, gasket etc. and replaces the 20+ yr. old part. Wifey says Hi, and says to say Hi to yours.
That's probably a good point CFI-EFI, the normal steps are 1-40, so I think you could still have a carbon build up that just may be hard to see.
Old Jul 16, 2006 | 01:06 PM
CFI-EFI's Avatar
CFI-EFI
Rick:
The IAC quit working? Even a new IAC can't pass air through block passages. Has the TB been cleaned or checked?
I hope that is a typo.
RACE ON!!!
Old Jul 16, 2006 | 01:21 PM
rick lambert
Probably a typo, .55 would be right at idle, but he could have been measuring at WOT in that case 5 volts would be correct.
Old Jul 16, 2006 | 01:26 PM
vinnies87's Avatar
vinnies87
RACE ON!!!
Replace IAC and cleaned TB passage, wasn't really dirty but IAC was black. scanner shows IAC Step counts @ 134. Disconnected MAF and she runs but idle jumps between 6 & 9-10 with MAF disconnected.
Going to try to reset IAC
Injector pulse @ 2.9ms
Throttle sensor .58
Fuel Rail pressure @ 42psi and holding
Per this test, ruff & var idle.
Old Jul 16, 2006 | 01:44 PM
vinnies87's Avatar
vinnies87
IAC Setting and test:
1. Followed IAC procedure,
engine off - A/B Diag mode
Ign ON - 30 sec
Ign ON - disconnected iac connector
Remove Diag mode
Start engine (at this point she ran, had to keep idle up but she was running) - on to ops temp
Engine - off
Connected IAC
Restarted and she was still REAL RUFF and WOULD CHOKE OUT AND DIE.
Disconnected MAF and same results.
vinnies87's Avatar
vinnies87
Ign ON - 30 sec
Remove Diag mode
Engine - off
Connected IAC
Old Jul 16, 2006 | 01:51 PM
JackDidley's Avatar
JackDidley
Vin, have you looked at any spark plugs, I am sure you are doing all the right things. I am just throwing out suggestions. If it had been MAF it woud have improved when un plugged.
Old Jul 16, 2006 | 02:12 PM
vinnies87's Avatar
vinnies87
Agreeded... Haven't pulled any plugs as of yet... driving me nuts... the injectors are new 7mos from 5-O and have had no issues to date.
Old Jul 16, 2006 | 02:19 PM
rick lambert
Could be wrong, but I thought I read somewhere you had to disconnect the EST to set the IAC.
You know, something just occured to me, didn't you just put the new plenum and runners on? I know you're detail oriented, but I'd definetly check for vac. leaks. Just a thought.
To HELP ENGINE -C4 L98 Stock
Old Jul 16, 2006 | 02:29 PM
vinnies87's Avatar
vinnies87
Yea, I had 2 different techs on that, did it both ways.... LOL.... Had slight improvement on its idle, with pedal help, when setting the IAC, but she now runs so very ruff with bouncing idle and disconnect MAF doesn't help, so rules MAF out.. New IAC and set 2 times and no error codes... Pressure still holds @ 42psi, been there for 40 minutes now.
Old Jul 16, 2006 | 02:40 PM
rick lambert
Vac leaks? also you may want to pull the hose from the EGR, plug it and see if that makes a difference.
Old Jul 16, 2006 | 03:29 PM
vinnies87's Avatar
vinnies87
Well, this is a new one on me.... no leaks, did the water test - vacume fine, so decided that maybe I'd f**k with the ECM and chip... okay, pulled and switched with spare one, and replaced back with stock chip... reset TPS/IDLE/IAC/TIMING - AND SHE PURRS LIKE BEFORE.
So replaced ECM back, stock chip, reset it all again, just to make sure and she RUNS FINE. So, I'm thinking that maybe the ECM go locked in a state and until the chip was removed, reseated and powered down, she then reset herself.
Being a CIO, this was my last attempt before call one of the MGCC club members who owns a Corvette Speciality Shop and having it trailered down there.
What can you say... GREMLINS for sure
