HELP ENGINE -C4 L98 Stock
Old Jul 16, 2006 | 03:29 PM
kopbet89c4's Avatar
kopbet89c4
I'd test your coil, ignition control module and coil pickup. Is your fuel dirty? Does your car stall under part throttle and/or stall out when you press the gas pedal from a stop?
Old Jul 16, 2006 | 03:39 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
No, she's fine, runs strong now, idle sweet and smooth, just like before, all came down to the ECM and Chip, I think, that was the last in the list of testing and changes before she reverted back to normal.
Old Jul 16, 2006 | 03:47 PM
rick lambert's Avatar
rick lambert
Maybe just a bad connection on the ECM, when you put in the other you cured the connection problem.
Old Jul 16, 2006 | 03:54 PM
JackDidley's Avatar
JackDidley
Good fix. I never saw that one coming. That ECM is hiding up in the dash and I pretty much take it for granted. Last place I would have looked.
Old Jul 16, 2006 | 11:18 PM
vinnies87's Avatar
vinnies87
That the truth, 16hrs working on it, and it was a 1 hr remove/replace and running, funny the most time after that took to adjust: Timing, IAC, TPS, and dress it back up... Gonna have to add this to the check list for issues.
