I have a '96 LT4 w/ BBK 52mm TB. Having some idle issues w/ the A/C on and was told to clean the IAC as that should correct the problem. Cleaned my TB recently but left it on the car and was told this time to remove it to clean and do the IAC as well - which requires removing the TB to clean.
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I would get a new throttle body gasket. The IAC motor should have a rubber o-ring. Just be careful taking the o-ring off of the motor. Don't get the cleaner on the o-ring. Clean it up real good and let it air dry. Reassemble and you should be good to go.
Any tips on this?
Thx,
Jeff
Hey Jeff, thanks for the question. I'm having the same problem. When I turn on the AC, the idle goes to crap. Let's get together sometime.
I just used an old toothbrush and a can of Valvoline Synthetic TB Cleaner to clean my IAC spring and pintle.
Be sure and replace the IAC gasket.
You can make one from gasket paper if you can't locate one at your parts counter.
on the cleaning and I was unable to locate just the IAC gasket. Make sure when you install the IAC back into housing...that the tip of the pintle is no further than 1 1/8" from the flange. If it is any further it may damage the motor windings.
My AC compressor was going bad and caused bad idle and a code for the IAC. Really bogged it down. Is it spinning freely? New compressor cured my idle with AC on. Just a suggestion.
I couldn't find just the IAC gasket either. I just bought the throttle body gasket set from Auto zone. Came with the top plate and bottom coolant passage gaskets, IAC gasket, EGR (?) gasket and the throttle body to plenum gasket. If I remember correctly it was $5.99 for the set for my 91.
Also, don't forget to clamp the TB engine coolant hose (LT-1, LT-4) before you remove it or you'll risk dousing your Opti with just enough coolant to possibly tank it.
Hey Marcus,
I actually fixed this a while back. Took the car to Bill's (ZFDoc) & pulled the TB. Cleaned it thoroughly as well as the IAC and *bingo*, problem solved.
Mike @ ADS told me he was quite sure that the IAC was the culprit..."needed cleaning". You have to remove the TB to get to it so I went ahead & did a serious cleaning job on both. Idle immediately returned to normal.
Give me a call or PM me if you want to get together.
Don't forget to put a dab of motor oil around the TB gasket before you screw it back to the TB housing. This ensures an air-tight seal and prevents possible vacuum leak.
I use a high vac silicone grease on all TB gaskets just to be sure. It also makes it easier to disassemble next time.
Scan it first and verify that there's an a/c signal along with an increase in IAC counts. A/c signal is from the Programmer with the circuit completed through the Low Pressure Switch. The IAC counts are actually bumped up a nano second before the ECM grounds the Compressor Relay, but it's difficult to capture that on a scan. In any event, with the compressor turning, your scan should show "Yes" and the IAC counts should increase to something in the 20's. When the low pressure contacts open, the compressor should shut off and the counts should drop. If that much is there, suspect the IAC. If it isn't you'll need to troubleshoot the a/c signal, ECM.
