pre cats are off..
Old Sep 3, 2001 | 03:48 PM
jackyy's Avatar
jackyy
Default pre cats are off..
i have a 91 vette..L98 i took off the precats and whqat a difference in power...now if i take off my main cat what should i expect out of my car....
thanx
Old Sep 3, 2001 | 06:25 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Re: pre cats are off.. (jackyy)
what year car....?.....any probs with codes or passing emissions.?...where do you live....how bout loudness...any change.....?....or torque curve....I have heard...that the curve moves further on up the line........please explain...thanks...cause i want to ....to my 1990 automatic
Old Sep 3, 2001 | 06:30 PM
Topless87's Avatar
Topless87
Default Re: pre cats are off.. (XtremeVette)
How do you "take off" the pre-cats? I thought they were part of the pipe? Can they be removed? Or did you get a new front Y-pipe?
Old Sep 3, 2001 | 06:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have no pre-cats, hi-flow cat (maybe 5hp loss) and hi-flow cat back. With intake, etc mods it was worth ~25HP at the crank. What you get despends on how restrive the rest of the exhaust is and if your L98 can gulp in enough air (I did some intake mods before exhaust).
Old Sep 3, 2001 | 06:54 PM
jackyy's Avatar
jackyy
ya i just took off the pre cats and replaced it with a y pipe from a 85 vette..the tubes are even larger than the 91...now i want to take off the main cat...oh ya the sound is better than before
thanx
Old Sep 3, 2001 | 07:00 PM
65Z01's Avatar
65Z01
It makes a big difference in sound.
I had mine on a dyno last night; at about 10ft from the rt rear wheel at 5200rpm in 3rd gear she was realy mean!:yesnod:
Old Sep 3, 2001 | 10:23 PM
91Vette's Avatar
91Vette
Did you do the work yourself? I've heard that getting the bolts loose from the exhaust headers can be a nightmare.
Old Sep 3, 2001 | 10:27 PM
KYVette90's Avatar
KYVette90
Default Re: pre cats are off.. (91Vette)
Did you get any codes on your computer? How will this affect the engine performance? Any cons? :confused:
Old Sep 4, 2001 | 03:34 AM
65Z01's Avatar
65Z01
Default Re: pre cats are off.. (KYVette90)
No codes, more HP to the rear wheels and latest trip mileage was 31mpg, up from 29+mpg last year.
If you don't like the throaty exhaust note you might not like it.
Old Sep 4, 2001 | 04:07 AM
XtremeVette
throaty?....or boomy?...with lots of resonance...I like throaty nice gurgle noise...not a constant low bass resonance hum.....which would you describe it as..?....and did you throw any codes?....
Old Sep 4, 2001 | 05:16 AM
Cratzy's Avatar
Cratzy
I did my pre-cats, and I really like the sound and feeling. It is like with headers.
I had no problems removing the old pipe except from the main cat, where it was stucked. But I cut the pipes just after the pre-cats and welded on new pipes. No problems!
I didn' t get any codes. Remember that you have the 02-sensor before the pre-cats and if you cut them off and replace them with pipes, like I did, you will have to put the 02-sensor back in the new pipes. Requires some welding.
I am also planning on changing my main cat to a freeflow race cat. Have anyone done this and did you gain any?
:D
Old Sep 4, 2001 | 06:00 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Re: pre cats are off.. (Cratzy)
I removed mine also. Its a cheap mod. The car did not get much louder, and SOTP gains are little but there. Can't go wrong, no codes or problems. I left the main high flow cat and tested better on the sniffer then most new cars!!
To pre cats are off..
