1993 Keyless entry remote programing?
Old Jul 18, 2006 | 10:21 AM
vettespd93's Avatar
vettespd93
Default 1993 Keyless entry remote programing?
Is there any other way to program a keyless entry remote without having the owners manual? is there a website or is it the same for any vette. I have a 93 that I need to do this to
Old Jul 18, 2006 | 10:52 AM
merlot566jka's Avatar
merlot566jka
put the transmitter fob about 40 ft from the vehicle. turn your ignition on. press the trip/odo button twice. within 5 seconds press the fuel info button and hold until the passive keyless entry light comes on on the idiot lights. turn the key off and the 'pke' light should be blinking. you have 2 mins to get the key fob transmitter to the car and within range. when it enters the range the pke light should stay on. repeat for more fobs.
if the light does not stay on, the fob could be bad or your going through what i am...they fob is good an already programmed to the vehicle.
also if you were asking about how to program to turn it on or off, or change the door opening sequence your going to have to search for it, cause I'm lost in all the pke posts right now and i cannot find it off hand.
hope this helps!!
Old Jul 18, 2006 | 11:55 AM
Red Dwarf's Avatar
Red Dwarf
http://forums.corvetteforum.com/show...m_id=34&arch=1
To 1993 Keyless entry remote programing?
