Correction to TB By-pass
Old Sep 3, 2001 | 05:24 PM
olephart's Avatar
olephart
Default Correction to TB By-pass
If you are doing the TB by-pass on a 96, the instructions in the Tech Tips could use a little revision.
1. All of the fittings/hoses are 3/8
2. The size of the rubber caps used to plug the TB nipples is relatively meaningless. Eyeball the size of the hole in them. I found some labeled 1/2" that fit good. 3/8" wouldn't go on.
Old Sep 3, 2001 | 11:10 PM
mikey's Avatar
mikey
Default Re: Correction to TB By-pass (olephart)
i think it's actually different for the '95's also.. i know my '94 hose setup is different than the '95's and '96's.
