looking at the installed rods - tech question.
Old Jul 19, 2006 | 10:52 AM
conv90's Avatar
conv90
Default looking at the installed rods - tech question.
I don't know how to explain in simple words...
I try...
Which side of the rods should be near the counterweight of the crank and wich side near the adjacent rod?
I'm speaking of the big end of the rod linked to the crank journal.
Yesterday i was under the engine with the pan removed.
I noticed that looking at the bottom side of the rods , these rods (eagle SIR 'I' beam) are not symmetrical.
One side (the one near the counterweight or the one near the other rod ..I don't remember I'll check this evening) has more meat. ...It's more thick. You can see by eye.
So now the question is: " Which side of the rods should be near the counterweight of the crank (the thick or the tinner?..) and which side near the adjacent rod?
-Beppe-
Old Jul 19, 2006 | 11:40 AM
CFI-EFI's Avatar
CFI-EFI
It is hard to tell from your description. If there is an oil squirt hole, it goes to the in (cam) side. If the bore that the rod bearing fits into has a larger chamfer on one side than the other, the larger chamfer goes toward the outside (crank counter weight). Larger, flatter, cheeks make for a better thrust surface and should face each other, rod to rod. In case of multiple conditions, I've listed them in the order of importance. I would contact Eagle if you have any doubt.
RACE ON!!!
Old Jul 19, 2006 | 12:14 PM
conv90's Avatar
conv90
RACE ON!!!
Thank you.
I never received a reply from Eagle, and I don't expect to recive it for this ...
This evening I'll check again uder the engine.
It seems that this NOT SYMMETRY can lead to a "not centered" piston in the bore so i think it's impossible to do it in the wrong way...
...mmmm I said a stupid thing... the rods are floating pin style... so there is the possibility that the axle of the rod is not in the center of the 4.030 bore... and that the force applied is not in the center of the wrist pin...
-Beppe-
Old Jul 19, 2006 | 02:28 PM
CFI-EFI's Avatar
CFI-EFI
Even with pressed pins, the pin, with the rod pressed onto it, is free to move back and forth in the piston pin bore.
RACE ON!!!
Old Jul 19, 2006 | 08:45 PM
DanZ51's Avatar
DanZ51
Just read this last night. Chamfered side to the crank cheek.
http://popularhotrodding.com/enginem...tallation.html
To looking at the installed rods - tech question.
