code 1661
Old Jul 19, 2006 | 06:58 PM
SMAR1477's Avatar
SMAR1477
Default code 1661
anyone have a idea of what code 1661 is on a 96 lt1 auto????????????
Old Jul 19, 2006 | 09:48 PM
ultraviolet70's Avatar
ultraviolet70
P1661 is a MIL control circuit code (SES sevice engine soon/check
engine light).
Does your SES light come on?
Old Jul 19, 2006 | 11:59 PM
SMAR1477's Avatar
SMAR1477
the service engine light came on thats why i checked the code? what does it mean? how do i go about fixing it???????????/
Old Jul 20, 2006 | 11:50 AM
ultraviolet70
If the SES light is actually coming on I honestly don't know. Usally that code sets when there is an open in the SES circuit I haven't seen any GM vehicles set that code when the light works. If you clear the code, does it reset?
Old Jul 20, 2006 | 11:55 AM
ultraviolet70
The only other thing I can think of is a faulty PCM, or the SES control
circuit is shorted to ground (circuit comes out of PCM connector 4 pin 9
brown wire with white tracer). You could try cutting the wire at close to the PCM if the light goes out the PCM is at fault ifthe light stays on it's shorted to ground (PCM controls ground side of circuit).
Old Jul 20, 2006 | 04:05 PM
SMAR1477's Avatar
SMAR1477
thanks for the responce. yes i can clear the code it comes back after about 5 min. where is the pcm located at?
Old Jul 21, 2006 | 02:10 AM
SMAR1477's Avatar
SMAR1477
problem fixed apparently it was the headlight switch making a bad connection from no use.
Old Jul 21, 2006 | 10:11 AM
ultraviolet70
That's a new one to me. Glad to hear you got it.
To code 1661
