Pretty down home, I made it in a pinch. I can't remember if I posted this before. So anyway I'm posting this because we've had several discussions lately about finding TDC with a degree wheel and the heads are on.
Beat the snot out of an old spark plug emptying it of the ceramic. I ground the ceramic flush at both ends then stuck it in a 5/8 socket. Put the drive end down on my vise, most vises have a nice flat for beating stuff on a hard surface. Took a punch and started whacking away at the ceramic. Do whatever works for you, a hammer drill with a masonry bit might work.
Thread the empty spark plug for a 3" long bolt, thread pitch doesn't really matter. I used whatever I had wasting space in my bolt bucket. Grind the head of the bolt round so as not to nick your piston. I chucked the bolt up in my drill and ran it against the grinding wheel, run the drill at high speed and shape it into a ball or close to it. I took off the first couple threads below the head also. You can go crazy with polishing the ball you make if you'd like, but I think if you get it somewhat round and don't force your piston into it real hard it's OK a bit rough.
Tighten the nut down to the spark plug so it doesn't rotate or move on you. After that the picture is pretty self explanatory.
very cool indeed. how do you know if you are on compression or exhaust stroke?
If you turn the engine over by hand you can tell compression stroke by covering the #1 plug hole with your finger and feel when the compression starts.
I'm not ragging on you here, but it seem's like an awful lot of work for a tool you can get from Summit for $7.88 http://store.summitracing.com/partde...5&autoview=sku. You don't wan't to hit the tool very hard with a piston because the damn bolt will bend also, ask me how I know!
Very clever solution but I'm still confused as to how it actually works. When building engines I've always found TDC with heads off using a dial indicator on the piston and a degree wheel on the crank. At TDC you can move several degree off TDC and have very little movement of the indicator. I don't remember the exact numbers but I think it was in the .010" range.
Maybe I'm dense or just don't get it but I just can't exactly see how your device allows you to find TDC with out having an existing reference. please elaborate for the thick headed out here.
Larry
Larry,
It's just a piston stop for use with a degree wheel. You install it, turn the engine one way till it hits the stop, note degree wheel reading, turn the other way till stop, note degree wheel reading, add the two together, divide by two, and at that number of degrees to the number the stop hits at and that tells you top dead center on the degree wheel. Then you turn the engine to that point, reset the degree wheel to zero, and then degree your cam. Takes longer to explain it than it does to do it though.
Well geeze, how hard are slaming the piston into the bolt? By the looks of the Summit one, mine is better. Mine won't dig into the piston and has a lock nut to make it completely solid in the spark plug housing. Use a grade 8 bolt if you must force the piston into it. I don't see why.
I think I did say this is for finding it with the heads on, also it sounds like a lot of work but took only about 15 minutes. And what do you do when you can't find yours or lent it out? Stop your work, place an order and wait. Heck no, not this Cowboy.
Thanks. Makes perfect sense. Now all I have to do is to figure out how to get a degree wheel to mount on an LT-1 hub with the engine in the car.
Very cool indeed! It's always nice to be able to do something and manufature something yourself! Good job! It's also nice to save some money by doing something like this as well!
Larry
Actually I think it would be easy, get a 7" degree wheel and contact cement some flat refrigerator magnets to the back side of it near the outer edge. Just use a hole saw to make the hole in the degree wheel large enough to slip your socket through to turn the crank bolt.
Since the stock balancer is 7" or 7 1/2" it should be easy to line up. And with the magnets, turning it to TDC when you figure out what it should be would be a piece of cake.
A 14" inch degree wheel would be more accurate, but we all know that won't fit with the motor in the car.
Heck when find TDC, you could make a nice line on your balancer and leave the pointer on for future cam checking. You would'nt need to find TDC again.
