Cruise Control
Old Jul 19, 2006 | 09:08 PM
KDuniverse's Avatar
KDuniverse
Default Cruise Control
It's not working. I replaced the 2 hoses from the servo, and it's still not working. What else is there to replace as far as vacuum lines? What else usually fails?
Old Jul 19, 2006 | 09:11 PM
zoro's Avatar
zoro
check the rubber diaphragm for leaks
Old Jul 19, 2006 | 09:18 PM
aminnich's Avatar
aminnich
A senior member that doesn't say what year and profile not filled out?
Ok, I will take a guess that it is an LT1/4. Most common options are:
2. Brake switch out of adjustment, or the
1. Reason, the little plastic vacuum fitting under the pass side fuel rail cracked.
Hope it is an easy fix.
Old Jul 20, 2006 | 03:32 AM
JasenZ51's Avatar
JasenZ51
I have a similiar problem, My Cruise works but slowly loses speed??? Has anybody ever heard of this?
Old Jul 20, 2006 | 07:22 AM
KDuniverse's Avatar
KDuniverse
A senior member who doesn't know how to read someone's profile, and additional info? shocking!
Anyway, I'll take a look to see if anything is cracked. Also, are those the only 2 vacuum lines for the cruise control?
To Cruise Control
