X-pipe vs. H-pipe
Old Jul 20, 2006 | 01:15 PM
padrummer1's Avatar
padrummer1
Default X-pipe vs. H-pipe
I am going to get a new exhaust sytem in the next month for my 91. The ca is highly modifed is no longer using the computer for reference. The exhaust I am currenty running is hooker long tubes, 3" X-pipe (dont know the maker, it was on the car when i got it) 3" pipe and flowmaster 40 series out back.
My question is us Vette guys run X-pipes but the hot rod/street rod crowd is still running an H or crossover pipe instead. What is the gain of the X-pipe over the traditional crossover pipe?
An exhaust shop had told me that the H-pipe equalizes the pressure in the pipes and helps reduce some of the raspyness under WOT. I assume that an X-pipe does the same thing?
What if I just ran straight pipe with nothing connecting them?
what do you think?
Old Jul 20, 2006 | 01:24 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
The "x" pipe was the natural improvement over the "H" pipe. The connections are smoothed out. Exhaust scavenging occurs quicker. HP & torque up!
IMHO, I would not run just straight pipes.
Old Jul 20, 2006 | 01:34 PM
GeosFun's Avatar
GeosFun
At my dragstrip, the hot setup is an X-pipe, usually in carburated big blocks are the one's I have seen. I am told there is additional scavenging due to the shape. This is more than equilization of pressure. But I have not seen any difinitive testing data
Old Jul 20, 2006 | 01:43 PM
vader86's Avatar
vader86
Unlikely you would see an appreciable dyno difference until you go to extreme combinations. They accomplish the same thing, but the X-pipe is more of an evolution.
Alot of guys just run what fits under the car. X-pipes might not fit under everything.
Old Jul 20, 2006 | 05:29 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
On all counts. I added a crossover in the 'hotspot' of my Power Effects system when I was running it. The difference in sound (smoother), torque and low end response was without a doubt noticeably improved.
Old Jul 20, 2006 | 06:34 PM
hip's Avatar
hip
I run long tube headers 3"exhaust with a H pipe mainly because my exhaust is 5 yrs old. There was a big difference in resonence in the car, allso I can drop my complete exhaust system with 3 collector bolts each side & 1 muffler mount bolt each side. It gets the whole thing out of the way easily
Old Jul 24, 2006 | 12:13 PM
padrummer1's Avatar
padrummer1
when you say it ran "smoother," does that mean less chop in the exhaust or did it change the tone of the exhaust?
were these differences compared to pipes with no connections? or was this a h-pipe to x-pipe conversion that created the noticible results?
Old Jul 24, 2006 | 12:55 PM
cv67's Avatar
cv67
St. Jude Donor '05
I doubt youll "feel" any difference between the H or X. Just put on what fits your car and budget.
Old Jul 24, 2006 | 01:01 PM
padrummer1's Avatar
padrummer1
part of the reason i am looking into other set-ups is that i am not happy with the current sound i have.
like i said, i am running long tubes, x-pipe, 3" pipe, hi-flo cats and flowmaster 40's
what i was thinking of doing was switching to 2 1/2" pipe, no cats, h-pipe and some sort of canister type muffler like the dynomax ultra flows or moroso tubes.
i know it will be super loud but the car sees very little street time and that is not really a concern for me anymore. i just want it to sound very mean!
Old Jul 24, 2006 | 08:59 PM
hip's Avatar
hip
Try just pulling the cats off first, I have the same setup as you but no cats. I do have a 12.8 comp 434 which I'm sure makes for more sound. I've been thinking of going to something quiter
Old Jul 24, 2006 | 10:54 PM
GS583's Avatar
GS583
The last NASCAR racer that I had the chance to peek underneath had an X pipe up ahead of the boom tube side exhaust tip. Those guys are after every HP available at just about any price except reliability. I would suspect if they are running them, there is a HP advantage, albeit maybe small. Perhaps some of the guys a bit closer to the racerbelt could comment as to what is under the racers this year.
Old Jul 24, 2006 | 11:52 PM
SHINOBI-X's Avatar
SHINOBI-X
I put on the x-pipe in place of my resonator and felt no gain SOTP feeling meter. Hard to tell,maybe gained 5-7hp? I saw almost no difference in sound actually,sorry to say but it wasn't a big deal to my LT1 car since its stock.
To X-pipe vs. H-pipe
