Hot '84 Coupe
Should I be concerned?
And the only way to correct this is to pull the radiator out and clean it by hand. On the 84, you can have your radiator out in less than 15 minutes.
C4 corvettes are bottom feeders....that is, they draw cooling air (and anything else they can suck up) into the radiator from the ground.
If it's never been done on your car, you will be amazed at what you find. I found gum wrappers, leaves, cig butts, a piece of a wal mart bag, and a nice big long deceased bumble bee.
Clean it with some good degreaser, straighten any bent fins, and your car will run considerably cooler. Your temp range is pretty normal, but my car ran much cooler after cleaning the radiator. I live in a very hot area, and I get about 185-190 at freeway speeds in 105 degree ambient temps. In traffic with the A/C blowing, about 200-210. At idle, it does the usual cycling thing with the A/C off, and runs about 225 with it on. Cools right back off after I get moving again.
RACE ON!!!
RACE ON!!!
Should I be concerned?It just needed it anyway. Well worth the effort when you see how bad it gets in there.
