C4 Lower Control Arm Removal
Old Jul 20, 2006 | 10:22 PM
Jim5pt7v8's Avatar
Jim5pt7v8
Default C4 Lower Control Arm Removal
Has anyone removed their lower control arms without using a spring compressor tool as the service manual suggests? Is it as simple as disconnecting the lower ball joint and letting the spring decompress all the way? I did this and it seems that there might be still pressure on the arm? Maybe this is due to the "twisting" of the bushings?
Any advice on this job would be helpful.
(I'm replacing the bushings to poly.)
Thanks-
Old Jul 20, 2006 | 11:39 PM
RickF's Avatar
RickF
Yes it is that simple. I just replaced the lower ball joints and the LCA bushings to poly on my 94. I placed a jack under the LCA and once the ball joint was free, slowly lowered it until the spring fully decompressed. The LCA has additional range of motion. You may need to coax the LCA away from the spring due to the rubber pad sticking to the LCA. I did this job and I am far from being ASE certified. BTW on reinstall I had the most trouble getting the sway bar link to line back up. The rest was easy... well, relatively easy.
Oh, one other thing. I had to remove a bolt on brace directly behind the LCAs and under the chassis in order to get the rearward LCA mounting bolts out. I was not happy to discover this extra work especially when I didn't jack the car very high thinking I would not need to get under it.
Best of luck
Old Jul 21, 2006 | 12:50 AM
86PACER's Avatar
86PACER
Just lower the lower control arm slowly with a jack. There will be a point where the spring will contact a stop and remain there. The control arm can then still be pushed down further by hand now free of spring tension. Unbolt and remove.
When you re-install, install bolts but not yet torqued to specs. Raise the control arm against spring tension with a jack, untill the car just begins to lift of the jackstand. This is when you now torque down the control arm bolts to spec. If you torque the bolts down with the control arm down at full droop, you can have binding issues.
To help re align the sway bar link, finish installing the control arms and lower the car to the ground. Now start the car and roll it back then forth some to settle the suspension down closer to normal ride height. This makes it much easier to aling and bolt up the sway bar end links.
Old Jul 21, 2006 | 11:39 AM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
with what they said it is a piece of cake and i just finised mine a week ago
Old Jul 22, 2006 | 12:34 AM
Jim5pt7v8's Avatar
Jim5pt7v8
Perfect...Thanks all!!
To C4 Lower Control Arm Removal
