Roller Rockers - Best by Test
Old Jul 21, 2006 | 01:42 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Roller Rockers - Best by Test
87/L98
I know there has been quite a bunch of tests by you guys concerning which has come out the best.... I know there 1.6 roller rockers, so which has come out on top...
thanks
vinnies87
Old Jul 21, 2006 | 09:30 AM
AKS Racing's Avatar
AKS Racing
I have run a few different ones. For individual stud mount rockers, I run the Comp Cam Pro Magnums on 7/16" studs. I run Jesel shaft rockers on my other.
Aaron
Old Jul 21, 2006 | 10:50 AM
CFI-EFI's Avatar
CFI-EFI
What is it, in your mind, that makes one "the best', or better than another?
RACE ON!!!
Old Jul 21, 2006 | 10:54 AM
vinnies87's Avatar
vinnies87
RACE ON!!!
Well, Stock engine, and want to upgrade the rockers, and not know which would be the best ones to go with, considering the 350 is stock on the heads (alum) and thats all i want to replace at this time. Besides i'm just starting to learn about this part of the engine.
Old Jul 21, 2006 | 11:00 AM
Vetracr's Avatar
Vetracr
BEST depends on your application, race or street? The Comp Cams roller tip rockers are fine for a street motor. If you are going to race you need a full roller fulcrum rocker. The Comp Cams fulcrum rockers can't take the heat. When I tried them in a race motor they fried in a few laps. The fulcrums and studs were blued from over heating. Took them out ASAP.
Larry
Old Jul 21, 2006 | 11:33 AM
CFI-EFI's Avatar
CFI-EFI
Maybe I need to rephrase that. What is it about the "BEST" that will be better than the one you don't want to use? What are you looking for? What do you value? Appearence? Price? Strength? Popularity? Name? What is it, in your mind, that makes one better than another?
RACE ON!!!
Old Jul 21, 2006 | 11:34 AM
vinnies87's Avatar
vinnies87
Larry
Larry: Thanks, as i posted to CFI, this is JUST for STREET, no racing, just wanting to add a little boost to the eng performance, and as i understand they should prob add 10-15hp. The runners & plenum are ported, and she has Hi-flow precat w/magnaflow exhaust.
Old Jul 21, 2006 | 11:36 AM
vinnies87's Avatar
vinnies87
RACE ON!!!
That just it, i don't really know WHICH ONE to use. Street only, no racing, best performance, Strength, best bang for the buck...
Old Jul 21, 2006 | 11:44 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Crane 1.6 RR's self aligning(Golds) work absoloutly great. Quiet and easy to install and adjust! Very happy with their product and would not change from them to another what so ever!
Thanks,Matt
Old Jul 21, 2006 | 02:36 PM
vinnies87's Avatar
vinnies87
Thanks,Matt
Matt:
Thanks thats the info i was looking for...
Old Jul 21, 2006 | 02:42 PM
vader86's Avatar
vader86
CC pro mags, crane gold
either is good
Old Jul 21, 2006 | 02:51 PM
CFI-EFI's Avatar
CFI-EFI
Does a happy customer make his selection "The Best"? Comp cams has several different offerings. Harlan Sharp was a pioneer in roller rocker arms, and there are many others with good products available. And speaking of roller rocker arms, do you even want rollers? There are some less expensive, non-roller, and roller tip, only, 1.6:1 rockers available, too. It all goes back to what you are looking for, and what YOU consider to be the attributes of "The Best".
RACE ON!!!
Old Jul 21, 2006 | 03:24 PM
vinnies87's Avatar
vinnies87
RACE ON!!!
CFI Thanks: As i posted back earlier: This is just trying to get more hp out of the stock engine, and not really knowing all the ins and outs of things, but reading, that RR give you some of the best hp for the $'s, with miminal engine work. So thats what i'm looking to try and accomplish. Maybe all in all the word "BEST" should only relate to personal taste.
tks
vinnies87
Old Jul 21, 2006 | 03:25 PM
vinnies87's Avatar
vinnies87
either is good
tks vader
vinnie
Old Jul 21, 2006 | 04:34 PM
Red Tornado's Avatar
Red Tornado
the answer to the best for you is: what level of peace of mind are you willing to purchase. its like insurance, you're only buying odds.
i purchased a more expensive insurance, and its only for the street: cc pro magnum's, non self-aligning, full rollers, 7/16" stud.
overkill? you bet. would i do it again? probably, maybe not.....
Old Jul 21, 2006 | 04:48 PM
vinnies87's Avatar
vinnies87
I hear ya:
Looks like its the:
Crane Gold CRN-10758-16
Brand: Crane Cams
Product Line: Crane Gold Race Extruded Rocker Arm Kits
Rocker Arm Ratio: 1.6
Rocker Arm Style: Full roller
Stud Size: 3/8 in.
Rocker Arm Material: Aluminum
Self-Aligning: Yes
Rocker Arm Body Style: Narrow
Rocker Arm Nut Style: Polylock
Slot Width (in): 0.600 in.
Maximum Spring Diameter (in): 1.630 in.
Old Jul 21, 2006 | 05:02 PM
geezel's Avatar
geezel
Less valve cover mods required with the Crane golds -vs- the Pro Magnums (the Crane golds are narrower).
To Roller Rockers - Best by Test
Old Jul 21, 2006 | 05:34 PM
USAsOnlyWay's Avatar
USAsOnlyWay
I have the Summit roller rockers, they are Scorpions repackaged though...shh don't tell anyone!
Also, I have CC Magnum roller tips with studs for sale....
http://forums.corvetteforum.com/show....php?t=1444274
I might be able to split it up, but this would be a really nice boost up for your motor.
Old Jul 21, 2006 | 05:52 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Larry
The Pro Magnums mentioned above do have roller fulcrums. You're confusing the Magnums with the Pro Magnums.
What would width have to do with valve cover clearance? The only valve cover issue I've ever heard of with either is the drip tabs. This seems to vary by which cover a given car has. Either way, it's a simple problem to remedy. The Cranes are essentially the same as what the LT4's come with, only they are set up to be adjustable when purchased in the aftermarket. The Pro Mags, although stainless steel, are still actually lighter than most aluminum RRs. They are also rebuildable if ever the need arises. Both are good selections for a street car that will be driven and even for racing up to their design limits.
Old Jul 21, 2006 | 06:02 PM
geezel's Avatar
geezel
I've had both... With the Crane golds it was just removing the drip tabs. When I went to the wider Comp Pro Mags I had to grind each side of the bolt towers as well as crimp the crap out of the breather units on the underside of the valve covers. No big deal really.
