Fly Wheel Question
Old Jul 21, 2006 | 12:50 PM
blue 85's Avatar
blue 85
Default Fly Wheel Question
have an 85 and put a 383 in to it used the stock fly wheel with a bolt on external balancer I want to put a new fly wheel on it when I change out my clutch the question is what is the diameter of the stock fly wheel and the tooth count is 153 I think. Input on this would be verry helpfull thank you
Old Jul 21, 2006 | 02:05 PM
CFI-EFI's Avatar
CFI-EFI
The tooth count IS 153. That will automatically make the flywheel the correct diameter. Your externally balanced, one piece rear seal, 383, takes the same imbalance weight as a stock 400. You will have to either reuse your bolt-on weight, or go for an aftermarket, 153 tooth, 400 (383) unbalanced, flywheel. All stock 400s came with 168 tooth flywheels or flexplates. The bigger flexplates will fit the 700R4/4L60(+E) bell housing area, but the flywheel won't fit inside the C4 manual trans bell housing.
RACE ON!!!
[EDIT]: The above in red is a typo. It should say, "two piece rear seal". I apologize if that has caused anyone any problems.
Old Jul 21, 2006 | 02:38 PM
redrose's Avatar
redrose
since you said ''clutch'' and ''383'', you apparently have a manual transmission and a 400 chevy crank...400 cranks fit two-piece rear seal blocks...99% of all chevy flywheels are 153 or 168 tooth (some race set-ups do use other sizes, doubtful that you'll see one)...you can put the larger 14''-168 tooth flywheel in, but you must use the corresponding bellhousing/starter,clutch linkage,misc. and header/exhaust pipe clearance will be a pita...easier to get a neutral balanced 12-3/4''-153 tooth 350 flywheel and have it balanced for the 400(383) crank--there is a factory m/t lightweight (15 lb) wheel, 153t, with external weight for the 454 big block/two piece seal that will only need minor rebalancing to use on the 383 and it is tested to 10k rpm...you are limited to 10.5'' clutch with the 153t, if you need to break more parts with a bigger clutch, you need the 168t wheel.
Old Jul 22, 2006 | 12:25 AM
blue 85's Avatar
blue 85
Thank for the input I fund a 153 tooth 400 in the summit catalog it is an 11 in so that will hopefuly work.
To Fly Wheel Question
