Headlight: metal gear or plastic?
Old Jul 22, 2006 | 09:24 AM
rsrandy's Avatar
rsrandy
Default Headlight: metal gear or plastic?
Hi.
I need to change the gears or bushings or both in my headlights. The bronze gear is available as is the plastic one. Any advice, any experience with upgrading (or so the ad says) to the bronze gear?
Thanks Randy
Old Jul 22, 2006 | 11:50 AM
MikeC4's Avatar
MikeC4
if you go with the bronze gear, you will never have to replace again..Nylon gears were used by GM simply to save $$$
Old Jul 22, 2006 | 12:35 PM
DonF's Avatar
DonF
Glass headlights wear out the plastic gears. Plastic headlights ava. from NAPA. Donf
Old Jul 22, 2006 | 05:54 PM
Pete K's Avatar
Pete K
One advantage of the plastic gear is that it will strip if the headlight jambs up. The gear acts like a mechanical circuit breaker, so to speak.
Old Jul 22, 2006 | 10:29 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Go with the plastic! Because should somethig happen the plastic gives out and the metal gear will destroy the gear on the motor for the headlight should something go wrong! Like I always say plastic and metal should not mix!!!
Thanks,Matt
To Headlight: metal gear or plastic?
