ac high side pressure
Old Jul 23, 2006 | 09:21 PM
mfi's Avatar
mfi
Default ac high side pressure
I want to hook up my gauges to the high side port on my 92. What type of port is this and what adapter do I need.
Old Jul 24, 2006 | 12:09 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Look at the schrader valve. If it's deeply recessed, you need to purchase the GM 91 and latter high side service adapter fitting.
Here's a picture at this url
http://www.sjdiscounttools.com/msc90338.html
If the schrader valve is not recessed, you need the normal service adapter fitting. The fittings on the adapters are 1/4 male and 3/16 female. The only difference between the two service adapters is how far each can depress the schrader valve.
Old Jul 24, 2006 | 01:33 AM
mfi's Avatar
mfi
Yes, thats it. Thanx.
Old Jul 24, 2006 | 10:44 AM
93*Corvette's Avatar
93*Corvette
This is the fitting you need. But remember, if you decide to convert to R134, this Bridgeport (or sometimes call Piedmont or "Deep-Throat") valve goes away.
To ac high side pressure
