a/c update, a/c carb advice needed.
Old Jul 23, 2006 | 11:36 PM
steve1ph2's Avatar
steve1ph2
Default a/c update, a/c carb advice needed.
short story, `90 a/c problems, i was able to jump the harness at the a/c clutch relay and make the clutch come on long enuf to add a can which was all it needed. sat in the car for about 5 minutes with cold air then turned it off. the problem is it will not come on normally with the relay in place or with the one i bought. the book says the next step is for me to check ckt 999 between the ecm and the relay. havent done that yet. the car is a carb conversion. iv jumped the temp and plugged in an old tps sensor as these are inputs needed by the ecm. the book says the ecm will engage the a/c clutch anytime unless any of the following conditions exist , high coolant temp,wot,high oil temp,high engine rpm,. what do yall think? any carb guys or a/c guys with advice? thanks.
