Removing Water Pump
Old Jul 24, 2006 | 01:33 PM
vettelt11992's Avatar
vettelt11992
Default Removing Water Pump
I was just wondering if it was necessary to remove the radiator and all its components to remove the water pump??? The only reason being that i cannot get the idler pulley that routes the belt around the water pump off.. Is there another way to get this pulley off, because the puller i have wont fit between the pulley and the radiator housing????
Please help!!!!!
thanks guys...
whoever can help I owe ya
Old Jul 24, 2006 | 01:48 PM
SJW's Avatar
SJW
Please help!!!!!
thanks guys...
Is this an LT1? If so, you shouldn't need any special tools or pullers to do a water pump, and the radiator can remain in the car. Remove the tensioner as a unit.
Be well,
SJW
Old Jul 24, 2006 | 02:28 PM
Aardwolf's Avatar
Aardwolf
On my car, I did not need to remove the radiator or the pulley.
Old Jul 24, 2006 | 03:12 PM
vettelt11992
there is a pulley in the way of the third bolt on the driver side, how do i get around this pulley???
Old Jul 24, 2006 | 03:26 PM
SJW's Avatar
SJW
Ah, yes. It's coming back to me now. I believe the power steering pump pulley partly obstructs access to a water pump bolt. The tensioner does not get in the way. Remove the belt and unbolt the PS pump. You don't need to remove it, but it may be helpful to be able to pull it forward a bit, if you don't have tools that will let you work around the pulley as-is. If memory serves (always a chancy proposition where mine's concerned), you should be able to get that bolt loose with swivel sockets, etc.
Be well,
SJW
Old Jul 24, 2006 | 03:50 PM
Vetracr's Avatar
Vetracr
The short bolt on the drivers side of the water pump on an LT-1 is obstructed by the PS pump(?) pulley. Just use a short socket (14mm I believe) and a universal joint to remove the bolt. Its not hard.
Larry
Old Jul 24, 2006 | 05:05 PM
wayne lowry's Avatar
wayne lowry
Don't need to remove the pulley or the power steering pump. Just basic hand tools, sockets, exstensions and maybe a universal.
Old Jul 24, 2006 | 06:02 PM
J H's Avatar
J H
I recently replaced the water pump on my 85 for the second time in 7 years. The first time I replaced the pump I worked around the PS pump pulley. But, this time I removed the pulley and the removal and installation was much, much easier. It was well worth the time it took to remove the pulley. You will, however, need a PS pump pulley remover.
Old Jul 24, 2006 | 06:22 PM
wayne lowry
He has a 1992 Corvette with a gear driven waterpump. Your 85 is completely different.
Old Jul 24, 2006 | 07:29 PM
rrhayden's Avatar
rrhayden
I have had my water pump off several times. It is the power steering pump pully you are talking about. Mine has sever slots and holes in the pully and by rotating it you can find one that lets you put a socket and extension through the pully onto the bolt. Good luck
Old Jul 24, 2006 | 10:04 PM
pcolt94's Avatar
pcolt94
You need a long wrench to release the tensioner, loosen the belt and slide it off. Use a pipe for additional leverage if you need to. Do not remove any pulleys as so said.
That one bolt is behind the power steering pulley and a combination of a universal and different lengths of extension will do it easy. Have a magnet handy. Each side has 2 long and 1 short bolt and thin fingers do help.
It is a tight fit after you get it loose to get by the A/C dryer. It will come out, done it to many times. Clean gasket surfaces well with razor blade. Glue the new gaskets with RTV of such to the block, center it well in the bolt pattern. This will prevent ripping the new gaskets off if you put them on the pump and squeeze it down there.
Align shaft (will take a few tries) to spline connection and torque to 30 ft lbs.
Old Jul 24, 2006 | 10:40 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
[QUOTE=pcolt94]You need a long wrench to release the tensioner, loosen the belt and slide it off. Use a pipe for additional leverage if you need to. Do not remove any pulleys as so said.
It is a tight fit after you get it loose to get by the A/C dryer. It will come out, done it to many times. Clean gasket surfaces well with raiser blade. Glue the new gaskets with RTV of such to the block, center it well in the bolt pattern. This will prevent ripping the new gaskets off if you put them on the pump and squeeze it down there.
To Removing Water Pump
