Difference between L98 Camaro and Vette Heads?
Old Jul 24, 2006 | 02:43 PM
Wheelman's Avatar
Wheelman
Default Difference between L98 Camaro and Vette Heads?
Is there any difference between the L98 head on my Corvette and a L98 Camaro Head? Is there anything else less expensive I may be able to find as a replacement for some new 113s?
Old Jul 24, 2006 | 03:55 PM
vader86's Avatar
vader86
I believe the camaro heads were iron, and they probably dont flow as well, but I dont know their casting #.
There is nothing less expensive that flows as well to my knowledge that is aluminum. Iron heads will carry a big tradeoff in weight.
Old Jul 24, 2006 | 04:40 PM
Blownfuel1's Avatar
Blownfuel1
Also, if the Camaro heads are 1987 or newer, your intake manifold will not work, because the iron heads got the revised intake center bolt angles. Aluminum L-98 Corvette heads never got this, as far as I know.
Old Jul 24, 2006 | 04:48 PM
Roadster89's Avatar
Roadster89
If memory serves, I think the EGR provisions are different. The corvette's EGR source feeds off the #8 exhaust pipe, and because of that I don't think vett heads had provisions for routing the center cylinder's exhaust ports into the intake manifold. But I could be wrong.
Old Jul 24, 2006 | 06:00 PM
Bruce Witherspoon's Avatar
Bruce Witherspoon
If I'm not mistaken weren't you looking for a head earlier this year? I know I already replied to your want add, and these guys are correct. The intakes are different as well as the heads. I have a complete L98 from a Fbody and the only things that are common are the shortblocks.
Old Jul 25, 2006 | 09:22 AM
Wheelman's Avatar
Wheelman
Thanks guys this is good to know! I think I may have located an inexpensive D-Port replacement on the forum
Old Jul 25, 2006 | 01:46 PM
DrEvil11417's Avatar
DrEvil11417
If memory serves, 14101083 and 0183 - they were used on crate motors and TBI motors as well
To Difference between L98 Camaro and Vette Heads?
