lt4 hotcam and NO2
Old Jul 24, 2006 | 10:51 PM
steve0178's Avatar
steve0178
Default lt4 hotcam and NO2
I was just wondering how well the cam does with no2. I plan on using a 75 or 100 dry shot. I was thinking of going with zex but im not set on a brand yet. Any suggestions would be appriciated.
Mods:
94 LT1 block with a 93 intake
vented opti spark (off of an 94+)
LT4 Hot Cam
1.6 Rockers / new springs
Headman Jeep Conversion headers
40 Series Flowmasters
ECU tune by Pcmforless.com
Also, would i need a re-tune?
Old Jul 24, 2006 | 11:04 PM
AKS Racing's Avatar
AKS Racing
Is this in the RX7? If so, that has to be a surprise for the unsuspecting.
Old Jul 25, 2006 | 12:47 AM
steve0178's Avatar
steve0178
yes actually it is
Old Jul 25, 2006 | 05:55 AM
93 ragtop's Avatar
93 ragtop
I talked to Alvin about doing this to mine as well. He suggested a chip or adapter he has that allows you to run 2 programs. 1 without nitrous and the other for nitrous. I believe it was controlled by a switch in the vehicle. My big concern is how much more abuse the stock bottom end of the motor can take.
Old Jul 25, 2006 | 10:06 AM
tjwong's Avatar
tjwong
You can just use a MSD or other ignition box that can take a input for NOS activation to retard the timing a few degrees when the NOS hits. He has a 94 and up PCM that is flashed and doesn't require a chip. A MSD Digital 6 box will work as will a Mallory 6 series or a Crane Hi-6 system. I tuned a RX7 equipped LT1 engine here in my area recently. It was a nice fit and ran very strong!
Old Jul 25, 2006 | 10:13 AM
86VX1's Avatar
86VX1
lt1 in an rx7? that's cool. what do you call it? rx1, if you had an lt4 you could always call it, rx4.
Old Jul 25, 2006 | 11:17 AM
93 ragtop's Avatar
93 ragtop
My mistake, I did not realize he had a 94 engine management system on the car. I seen a 94 block, a 93 intake, and tune by pcmforless.
Old Jul 25, 2006 | 11:26 AM
neat's Avatar
neat
The cam will operate just fine with nitrous.
The 92 in my signature was an LT4 hotcam car. On a 100 HP shot of nitrous it gained 116 RWHP and 242 (!) RWTQ. I don't know exactly what made the engine respond so well to the nitrous, but you would be using the same cam I was.
Good luck!
Old Jul 25, 2006 | 11:32 AM
rickneworleansla's Avatar
rickneworleansla
I have plans for a new cam as well.
Edit: I am currently using two separate programs that I can switch between in less than 10 minutes with the laptop. The one for the N20 has the timing retarded to reduce detonation and looses a few hp when not using nitrous. I was also told I could go the MSD ignition box route. I believe the new MSD optispark can change timing also but that is still a very new product.
Old Jul 25, 2006 | 11:34 AM
steve0178's Avatar
steve0178
Good luck!
wow thats incredible!
so all i would have to do is retard my timing right? Same ecu, no tuning, just an ignition amplifier?
Old Jul 25, 2006 | 11:44 AM
steve0178's Avatar
steve0178
my liscence says rx-570
Old Jul 25, 2006 | 11:55 AM
steve0178's Avatar
steve0178
Here are some pics of the setup for you guys
Old Jul 25, 2006 | 12:11 PM
86VX1's Avatar
86VX1
are those mustang rims? man you have enough room in there for a big block. do you know what the car weighs? have you ran on the quarter? i totally dig the swap, what do the import guys say when you pop the ;hood?
Old Jul 25, 2006 | 12:39 PM
steve0178's Avatar
steve0178
Its actually getting to be a somewhat common swap which kinda makes me mad!!! They are 99 mustang wheels...nice eye. The cars weigh anywhere between 2900 (convertibles with swap) to 2500 lightned. Mine is around 2750-2800. Havent taken it to the track but it dynoed at 279hp and 304 ft/lbs when it was TOTALLY stock with no cam or exhuast or anything. I haven't had it dyno'd since.
Import guys look at me like im crazy but they all like it a lot. There are the stupid rotarty guys that are die hard fans that say you "take the soul out of the car by pulling the rotary" sorry i like to have power and reliability!
A lot of times i ride around with my roomate who has a 71 datsun with a built carbed 350 chevy. Our cars sound almost exactly the same.
Old Jul 25, 2006 | 01:59 PM
93 ragtop's Avatar
93 ragtop
besides the enging and transmission, what all did you change to make it fit?
Old Jul 25, 2006 | 05:48 PM
steve0178's Avatar
steve0178
http://www.team140.com/faq/faq.php Lots of info on the swap
You need to modify the subframe, use differnt motor mounts, as well as wiring and all that good stuff, its not a hard swap by any means. Two companies specialize in the swap. Grannys speed shop, and Hinson supercars. The ls1 into the newer model rx7 is a little more complicated of a swap but makes for an AMAZING car! Thats my next goal.
Old Jul 25, 2006 | 06:03 PM
93 ragtop's Avatar
93 ragtop
there was a guy at our local track who had a older RX7. I believe it was a 81. But he had it tubbed. It was a nice car though.
To lt4 hotcam and NO2
