91 injector leak test
Old Jul 24, 2006 | 11:31 PM
rcr103's Avatar
rcr103
Default 91 injector leak test
What is the mininum psi leak down on a 91 ? and can somene tell me what ford injectors are the best for a 91? bought some used blue tops off ebay,are leaking by.Should buy new I guess.Thanks for any help.
Old Jul 25, 2006 | 12:42 AM
SunCr's Avatar
SunCr
Usually all drops should be within 10% of one another so if one drops rail pressure 15 psi none of the others should drop more than 1.5 psi less. Difficult to measure with most Pressure Gages as the increments are too close together to get an accurate measurement (at least for my 55 year old eyes!). You also need something to energize each injector for a milisecond and NAPA does carry such a tool for about $80 (I actually bought one 5 or 6 years ago and though it was fun to play with it, it's probably better to let someone with a bench to flowtest them). If Rich at Crusin Performance is still around, maybe someone can provide his web. Otherwise, Street & Performance - www.hotrodlane.cc - provides a similar service - flow testing, blueprinting and reconditioning for a decent price.
Old Jul 25, 2006 | 09:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you basing this on fuel pressure dropping ?? Have you pinched off the fuel lines to see if it is the check valve in pump or regulator ??
https://www.corvetteforum.com/techti...=192&TopicID=2
To 91 injector leak test
