Wierd Tach problem after MSD install
Old Jul 25, 2006 | 10:32 AM
crkemppainen's Avatar
crkemppainen
Default Wierd Tach problem after MSD install
I got a Digital6 box installed, and for some reason the tach won't go above 3K.
The car runs fine, the tachometer reads correctly below 3k, but as soon as I get after it a little and the needle gets up there, it falls to zero and lays still untill actual RPM is back below 3k
strange, huh?
Old Jul 25, 2006 | 12:15 PM
crkemppainen
Could it be the "tach filter" I hear so much about?
Old Jul 25, 2006 | 12:40 PM
crkemppainen
Does this belong in a different section? Moderators?
Old Jul 25, 2006 | 12:51 PM
90Indy's Avatar
90Indy
I wish I could tell you how to fix your problem. I am currently experiencing the exact symtoms with my 90 L98. I plan on bringing the wiring diagrams for both the aftermarket ignition system and the diagrams from my factory service manual to our electrical engineer at work. Hopefully, he can at least point me in a direction to start. I will post what he comes back with in a few days.
90Indy
Old Jul 25, 2006 | 12:56 PM
xflagz51's Avatar
xflagz51
I had this exact same problem trying to use the MSD Blaster HEI coil, the tach would wig out between 3500 and 3750. There is some kind of radio interfearance issue. The other thing that I found out is that this radio interfearance also tweeks the signal going to back to computer, which therefore tweeks the signal going out to the distributor to advance the timing under acceleration! I wound up installing a new factory coil and it went away. MSD does make a tach fix, don't know if it works or not. Their other suggestios sure didn't work.
Keep the rubber side down,
Adam.
Old Jul 25, 2006 | 02:09 PM
hookedup's Avatar
hookedup
Do a search for tach filter bypass, that should fix your problem.
Dave
Old Jul 25, 2006 | 06:04 PM
xflagz51's Avatar
xflagz51
Dave
You don't have to do a search, pick up the phone and call MSD and tell them what your problem is. They will send you the tach fix for free, they sent me one. Whether or not it will work for you is a different story.
Old Jul 25, 2006 | 06:17 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
http://forums.corvetteforum.com/show...+filter+bypass
Old Jul 27, 2006 | 09:51 PM
xflagz51's Avatar
xflagz51
I stand corrected. I posted that question last year and nobody said a thing.
To Wierd Tach problem after MSD install
