Courtesy light problem
Old Jul 25, 2006 | 10:41 PM
jmbatt's Avatar
jmbatt
Default Courtesy light problem
When I open my doors the courtesy lights do not go on. They do work with the headlight detent. Could it be the courtesy light switch? I checked the fuse for courtesy/clock and it looks ok plus the clock works fine. If the switch is bad is this an easy fix? Thanks.
Old Jul 26, 2006 | 12:30 AM
jfb's Avatar
jfb
You have problems with the door jamb switch and/or its ground.
