code 1661 please help?
Old Jul 26, 2006 | 02:21 AM
SMAR1477's Avatar
SMAR1477
Default code 1661 please help?
the "check engine" light come on and the only code is a 1661 code. says it is a manufactor code???? where do i start to figure out whats wrong?????????
Old Jul 26, 2006 | 08:42 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The only thing I can think of is a faulty PCM, or the SES control circuit is shorted to ground (circuit comes out of PCM connector 4 pin 9
brown wire with white tracer).
You could try cutting the wire close to the PCM. If the SES light goes out the PCM is at fault if the light stays on it's shorted to ground (PCM controls ground side of circuit).
Old Jul 26, 2006 | 11:26 AM
SMAR1477's Avatar
SMAR1477
one day last week the light actually went off for a day then came back on. where is the pcm located at????? where is that wire you mentioned located at on the car???????????
To code 1661 please help?
