Headlight Problems
I Have A 1985 Corvette, The Left Headlight Goes Up But Will Not Come Down / I Have Replaced Small & Large Gears, This Did Not Fix The Problem / Was Told To Replace Relays - After Replaced The Relay Still Headlight Goes Up But Will Not Go Down--any Ideas What To Do Next
General advice I could give here is to look at the one that works and try and see what the difference is with the one that doesn't. Is the linkage binding up somewhere? You have one that works right so that should help you diagnose it.
Yet another thing to check (don't you love it...) - My '85 had a brittle/broken wire in the 'harness' that loops around the headlight assy clipped to the hood. The flat gray/white/green wire set that runs to the motor below the hood cutout. Where that set ties into the bundle from the lamp itself and then runs down to the harness plug has to flex everytime the hood is opened - asking for trouble. I've Also fought bad electrical connections within the harness plugs themselves.
We are talking about a 21 year old car, afterall - no surprise that electrical issues like that crop up...
