HELP!!!ADJUSTING VALVES!!!
Old Sep 4, 2001 | 07:39 PM
24power's Avatar
24power
Default HELP!!!ADJUSTING VALVES!!!
1996 LT-1..got a lifter noise when car gets hot. can i quieten this adjusting the valves?? your technique..explain the best way on this motor?? thanks for all the help i've received on this board!!!!! :chevy :chevy :chevy :chevy went to 15/50 mobile 1 and it did help abit...
Old Sep 4, 2001 | 08:50 PM
vettenuts's Avatar
vettenuts
Default Re: HELP!!!ADJUSTING VALVES!!! (24power)
If I understand correctly, your lifters are quiet until hot, then noisy? If that is the case, I don't think adjustment will solve the problem Unless someone has altered the adjustment) and new lifters may be in order.
