Which head gaskets??
Old Jul 27, 2006 | 08:57 AM
MR NICE's Avatar
MR NICE
Default Which head gaskets??
Ok here is what I have,stock deck 85 block with 64cc bow tie iron heads 520. lift on the cam,what would be a good head gasket and what thickness should I run?Thanks for any help,let me know if more info is needed.
Old Jul 27, 2006 | 11:39 AM
CFI-EFI's Avatar
CFI-EFI
The minimum recommended piston to head clearance is .035". The minimum piston to valve clearance should be .090" to .100". Once you know YOUR dimensions, you will know what works.
RACE ON!!!
Old Jul 27, 2006 | 06:26 PM
MR NICE's Avatar
MR NICE
On a stock 85 block with stock pistons can I get away with a .028 thick gasket compressed?How can I check without a lot of work?Will I have to Clay the pistons?Anyone with a setup close to mine?
Old Jul 27, 2006 | 07:49 PM
LD85's Avatar
LD85
I would say YES, a stock 85 block, I believe, is .025" in the hole from the factory, at least mine was.
So you would have .053", but I, personally, would re-torque the heads after your first heat cycle.
Old Jul 27, 2006 | 08:02 PM
CFI-EFI's Avatar
CFI-EFI
You can check your deck height with feeler gauges. Clay is one good method to check for piston to valve clearance. I doubt that gasket will cause any piston to valve clearance problems, but if you check, you'll know.
RACE ON!!!
Old Jul 27, 2006 | 08:46 PM
MR NICE's Avatar
MR NICE
Thanks,would gm performance gaskets be any good?what other brand would you guys recommend?
To Which head gaskets??
