"Low Coolant"
Old Jul 27, 2006 | 05:54 PM
Shawn_65's Avatar
Shawn_65
Default "Low Coolant"
well, after adding a bunch of coolant over and over again and burping the system twice, I still get that Low coolant about a week after I fill her up.
But I finally made a break through, today I popped the hood and I could hear escaping air from the cap, it was slowly escaping. I wasn't sure if this means the cap is bad or if it means i have a leak somewhere in the system, or if the part under the cap is damaged.
but I hear the sound of escaping air at the cap. anyone know where I can get one, ordering online or autozone?
thnx a lot!
-Shawn
Old Jul 27, 2006 | 06:00 PM
vader86's Avatar
vader86
just go to autozone
Old Jul 27, 2006 | 06:01 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Look here http://www.madvet.com/shop?frame=3.138.935 or http://www.ecklers.com/find.asp? or http://www.zip-products.com/Zip/prod...544C126C1FA568 Hope this helps!
Thanks,Matt
Old Jul 27, 2006 | 06:14 PM
RRT vette's Avatar
RRT vette
Does sound as if you need a radiator cap...
Old Jul 27, 2006 | 06:21 PM
jimmers's Avatar
jimmers
Isn't the air supposed to escape after you turn the car off? Isn't that its way of releasing the pressure?? You guys may have remembered my threads about my coolant issues. I've tried 4 different rad caps and they are do that after the car is shut off. I don't mean to hijack the thread Shawn
Old Jul 27, 2006 | 08:40 PM
CFI-EFI's Avatar
CFI-EFI
No. The pressure is supposed to go back to where it came from. When the engine heats up the coolant, and the little bit of air, expand. The excess coolant is forced past the pressure cap (at it's release pressure) into the reservoir. As the engine cools after shut down, everything contracts and a vacuum forms in the cooling system. The properly operating radiator cap valve opens and coolant is drawn back from the below water level overflow tube in the reservoir. If the cap leaks pressure to anywhere other than the overflow, there will be less and less coolant to recapture and no vacuum to recapture it with.
RACE ON!!!
Old Jul 27, 2006 | 11:51 PM
Shawn_65's Avatar
Shawn_65
RACE ON!!!
would the cap leaking pressure to the overflow sound like I described? or would you not be able to hear it?
Old Jul 28, 2006 | 08:52 AM
RRT vette's Avatar
RRT vette
On my 86E if I let the engine temp get to about 230* and shut it off I can hear a bubbling sound at the reservoir. If I shut the engine off at around 180-200* the sound is not present. But no air comes from the cap.
Old Jul 28, 2006 | 02:25 PM
CFI-EFI's Avatar
CFI-EFI
You should hear water flowing, or the bubbling (actually boiling) as described above. If you hear air, by listening at the reservoir cap, chances are the radiator wasn't as full as it should have been. If you hear air escaping from anywhere else, you have found something to fix.
RACE ON!!!
To "Low Coolant"
