Ok, I have a question and maybe looking for whatever is easier/popular to do. I would like to change stock distributor or ignition upgrade. Anyway does anyone make a drop in distributor or should I just use a MSD box as a upgrade. I am going to a new 383 but my old dist. has 180,000 miles of use and I fell it would be wise to do something. Thanks for the help/advice.
I'll let the others chime in for the upgrades,but I do know you can rebuild your distributor fairly cheap and easy.The pick up can be replaced along with new module and etc.I think the circuit board can still be bought from suppliers like napa and etc.Even a new gear can be pressed on if the old one is bad.
Theres a few new units(aftermarket) you can buy but have no experience to offer on them.I know others have used the msd and other units with success here.Im sure they will tell ya more.
It sounds like you are looking to waste some money. Unless the 383 has quite high compression pressures, or is going to be expected to turn very high rpms, your HEI is more than capable. Make sure it is in good condition. You can buy a rebuilt, but you will get a better quality refurbish if you replace the bushings and set the end play, yourself.
7000 rpms is pretty high. I shift my stocker at 6000 and NO problems. I have a friend with an alcohol burning 406 that runs 10s on an HEI. He shifts between 7800 and 8000 rpms. He does have a hp module and coil. An ignition system will only supply the volts needed to jump the gap. If the HEI CAN supply 40,000 volts, the "Fancy" ignition 60,000 volts, and it takes 15,000 volts to jump the gap of the plugs, then BOTH the HEI and the "Fancy" will supply, only, the required 15,000 volts. I would test and verify a need, before I waste money on something I don't know I need and can't see the results of.
RACE ON!!!
Voltage is really not the issue here. It's How long it takes for the coil to recharge during firing. At 7000rpm, you don't have a whole lot of time to recharge that coil before the next firing event. Thats where CDI ignitions help. Better yet, a distributorless ignition with CNP.
The voltage isnt the big factor here. It's charging the coil.
No fair. I said it first. Read what you quoted me saying.
RACE ON!!!
Not dissagreeing with you at all, just wanted to add my 2 cents about high-rpm use. Your correct in the voltage thing, but thats just the first step. Theres the dwell time issue that can become a problem. I've seeen motors skip at 6200rpm, and others good at 7k. Some coils need less time to charge than others.
