Tech Tip: Easier radiator access.
Old Jul 28, 2006 | 11:37 PM
SJW's Avatar
SJW
Default Tech Tip: Easier radiator access.
Last week I swapped out the radiator in my '94. All in all, it wasn't such a bad chore, but there was one part of the job that truly annoyed me. There are six small screws with 7mm hex heads that secure the lower portion of the upper radiator support to the lower radiator support.
These screws are located three on each side, forward of the A/C condenser, and down between the radiator support and the frame rails. Access to four of these six screws is, to put it politely, lousy. It was a genuine pain in the **** getting them out, and consumed precious time that I could have spent drinking cold beer.
As I was beginning to reassemble everything, I found myself muttering to myself under my breath about the prospect of dealing with reinstalling these screws. "Was this really the best that the engineers could have done with this? Hmm... Maybe we can improve on this..."
Try this as you put yours back together:
Remove the six J-Nuts from the upper radiator support. They are visible in the photo below, three on each side:
Here's a close-up shot of a portion of the upper radiator support with three of the J-Nuts removed:
Install these J-Nuts on the lower radiator support as shown in the next two photos.
Driver's side:
Passenger's side (note that photo was taken from driver's side):
Now you can install the screws from the opposite direction. This allows you to run them in through the air intake opening below the front bumper. It's MUCH easier to install the screws this way, and it'll be every bit as easy to remove them again at some future date.
One warning:
Make sure that everything is positioned such that the screw tips are not able to contact such items as wiring and the AIR pump's air intake hose (easy enough to do, just be sure to pay attention to this so that nothing gets damaged).
Be well,
SJW
Old Jul 28, 2006 | 11:59 PM
ALLT4's Avatar
ALLT4
I posted this a while back, maybe two weeks ago.
http://forums.corvetteforum.com/show....php?t=1435908
I can't remember who suggested it but I tackled this little mod that should make life much easier. I had nothing better to do while I'm waiting for my heads to come back from the machine shop.
7 tools, 1 can of semi-gloss paint (makes it look factory) and about twenty minutes of time.
Of course if you have to take the whole box out it will take much longer.
The top tinnerman goes on with no modding, the second one needs a bit of filing and the bottom one needs a bunch so the tinnerman hole aligns with the hole already there.
Old Jul 29, 2006 | 12:31 AM
SJW's Avatar
SJW
Sorry about the dupe, folks. I missed that thread.
FWIW, I didn't have to do any filing/mods to get the J-Nuts to align well enough with the existing holes. I also didn't remove the lower radiator support to do this mod...
Be well,
SJW
Old Jul 29, 2006 | 12:53 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Theres a shroud mod I did on my former 86,even though there are differences in design from later models.Not hijacking but posting in case anyone is reading and wondering about their earlier cars too.
I found that on the 86,the plastic shroud has 2 parts,upper and lower.
Its not too bad to remove the top upper shroud screws if you have a power tool...however the shroud is shaped so youre forced to remove the tranny cooler line and upper rad hose.
I trim cut the top shroud bottom edges some at both ends which would have normally been in the way of the cooler lines,hose,etc when pulling it out,so now theres less time to remove and no need to remove the tranny cooler lines or etc.It even allows you to slip the top shroud off without having to remove the top rad hose.
Did this to make periodic cleaning of the leaves and junk that gets built up in there between the rad and condensor.Putting it back together,still felt as sturdy.Dont know why GM felt it was necessary to mold the shroud the way the did,forcing one to remove stuff that doesnt need to come off if youre not planning to pull the rad out.
Theres also an old tech tip,Not sure if still on the forum,but I did it on my 86 as well.The 2 plastic *****/2 shroud studs that hold the air intake box to the upper rad shroud has a tendency to spin out of its bottom insert hole and making it impossible to get off.
Using the tip,I took the air intake box off,made sure the 2 intake studs was aligned up,drilled a hole in each of them on the side of the stud through the thin metal plate it has under the shroud and used a pop rivet on both sides to keep the screw tab firmly in place.Taking the **** off never spun the bottom of the screw again.It was very simple to do.(note,use caution when drilling this ON the car,dont hit the radiator or anything with the drill bit..theres room but can be close)
Yours was a also great idea for the later design of the shroud.
Old Jul 29, 2006 | 01:09 AM
ALLT4's Avatar
ALLT4
It'll work without filing, but I wanted the holes to align perfectly "at rest"
Without filing the those slots you'll have to pull a little on the shroud to make the holes line up and get the screw through.
This was on my '96, other years, your mileage may vary.
No, you don't have to pull the whole thing out. Mine was already out for other work I was doing at the time and made it real easy to do this mod at my leisure.
I'm glad you posted this because when I did no one paid attention at all so I figure everyone knew about this. I'm interested to see how this one goes.
Old Jul 29, 2006 | 09:26 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
That tip was posted several years ago. But it's always nice to see it again as a reminder.
Old Jul 29, 2006 | 09:36 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
And I'd never seen it before. Those little boogers are indeed a PITA as are. Thanks for the tip!
Old Jul 29, 2006 | 09:58 AM
SJW's Avatar
SJW
It was a bit of a hassle getting the upper support free of the car on my '94, because the flange on the passenger's side was trapped under the A/C lines. By lifting the driver's side up high, I was able to rotate the thing enough to get the flange to clear the lines, but it didn't impress me that this was necessary. Mine's a ZF-6, so trans cooler lines weren't an issue. I considered trimming this flange a bit before re-installing it, but decided against it so as to not alter the factory appearance too much (but I think I'll wish I'd done it next time I need to remove that thing).
The only other problem I had was getting the condenser to properly engage the rubber cushion on the driver's side of the upper support as I was reassembling everything. It seemed necessary to be able to nudge things around a bit as it was going together -- except that as it was going together it was no longer possible to get a hand or tool in there to do any nudging. I think the problem was made worse on my car because whoever assembled it last time (might have been at the factory) didn't get it aligned correctly, so the cushion was deformed. I never did find a clever solution for that problem, but finally got the thing to drop into place reasonably well.
Be well,
SJW
Old Jul 29, 2006 | 10:04 AM
SJW's Avatar
SJW
With the lower support in the car, it wasn't even evident to me that there may have been a slight misalignment of the J-Nuts to the holes. If I ever have it apart again, I'll check for this and file as required to improve things. Thanks for the tip.
I wish I'd seen your original post about this. I had actually begun putting it back together as it originally was before the idea came to me, and by then I'd already had two of the difficult screws reinstalled. I don't have time to read every post, and I skip a lot of them if the title doesn't grab my attention. I'm sure I miss quite a bit of good stuff...
Be well,
SJW
Old Jul 29, 2006 | 10:07 AM
SJW's Avatar
SJW
I've only been here since mid-'05, so I'm sure I missed the original post. And I overlooked the post a few weeks ago, also. I guess dupes do sometimes prove useful...
Be well,
SJW
Old Jul 29, 2006 | 10:32 AM
ALLT4's Avatar
ALLT4
I remember the first time I tried to get those screws out, there was much cussing. If the engineer was in front of me while I was trying to get those out he'd be eatin' wrenches.
I gave up and pulled the whole dam thing the first time. The second time I planned to take the whole box out while I re-did the top end and a cam change. That was the golden opportunity to fix that little pain in the ***.
Old Jul 29, 2006 | 12:34 PM
Hotred94's Avatar
Hotred94
Are those six little screws even necessary? I reversed the clips on mine but then never bothered to put the screws back in. I'll probably do it some day. My 94 is missing the senser thing on the side; doesn't even have an unconnected fitting in the wiring loom to plug into. I wonder why?
Old Jul 29, 2006 | 01:01 PM
Jerris's Avatar
Jerris
That sensor is the outside air temp sensor and is only on cars that hane the electronic A/C control that shows the outside temp.
Thanks for the tip guys I will file it for future fefrence
Old Jul 29, 2006 | 01:40 PM
Hotred94's Avatar
Hotred94
Oh thanks! I thought the previous owner had maybe done something and forgot to reinstall it (ala-the local shade tree mechanic). I don't have the electronic A/C, that explains it.
Back on the subject of the 6 screws. Why would GM put so many screws in such a short seam? The only answer I can think of is they are trying to hold in any air that might escape. Three screws on each side seems to indicate there may be enough pressure in there to blow the seam open a bit, but it seems pretty stout to me even without the screws in it. Then I have this hole right there where the air temp sensor would go if I had electronic A/C. I'll bet that is loosing more air that the seam ever would.
Old Jul 29, 2006 | 02:41 PM
SJW's Avatar
SJW
I'd think that the biggest reason for those six screws is to keep the two halves of the core support together to prevent air leakage. It is an air duct, so they'd surely want to keep it relatively leak-free. And at 150 MPH, you can bet that joint would open up a bit.
You could seal the sensor hole in yours with duct tape, if you care about it.
Be well,
SJW
To Tech Tip: Easier radiator access.
