Intake Air Temp sensor?
Old Jul 29, 2006 | 01:06 PM
DrEvil11417's Avatar
DrEvil11417
Default Intake Air Temp sensor?
Is it ok to extend the wires and relocate the IAT sensor to my airbox on an '86?
Old Jul 29, 2006 | 01:11 PM
Jerris's Avatar
Jerris
It is OK to do it but it will not give you any performance gains and I consider it a waste of money.
Old Jul 29, 2006 | 01:12 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Thats a mod that many think dosn't do any good
Old Jul 29, 2006 | 01:14 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
And it doesn't do any good,, been several tech write ups concerning and testing data to boot and there isn't any gains by it.. again, another waste of money.
Old Jul 29, 2006 | 01:17 PM
vader86's Avatar
vader86
Useless mod
Old Jul 29, 2006 | 01:53 PM
RRT vette's Avatar
RRT vette
with the 4 posts above.
Old Jul 29, 2006 | 02:45 PM
DrEvil11417
It's not really a mod, i switched to an lt-1 manifold so i have to put it somewhere... i just wanted to make sure it wouldnt have any negative effects since the readings its getting in the plenum are probably hotter than in the airbox
Old Jul 29, 2006 | 04:03 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I used the relocation because of the price of the 92-93 duct. I'm using a 91 duct and like it much better.
Old Jul 29, 2006 | 04:19 PM
MrNuke's Avatar
MrNuke
It basically measures the cooler temp of the air entering the air stream, so giving you a bit more timing. It might work, but it might also work against you if your engine is running hot. I used it with many mods on my '85. Not sure if it helped or not, but seemed to work good as I got no knock or problems with the ram air I ran into the superram setup back then.
Old Jul 29, 2006 | 05:08 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Mine's relocated and my car makes way over 400 HP. It must work!
Old Jul 29, 2006 | 05:26 PM
davemack's Avatar
davemack
An IAT relocate is also a fast, inexpensive way to replace your manifold-mounted IAT if it fails. But, I'm told it can cause your engine to run rich, since the ECM is programmed to compensate for the extra heat generated by the original placement.
Old Jul 29, 2006 | 07:08 PM
Aardwolf's Avatar
Aardwolf
It's much easier to change, yes. I moved mine when I ported the plenum because it sticks up badly in front of the back drivers side runner.
Old Jul 29, 2006 | 07:21 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You can buy one here http://www.madvet.com/shop?frame=3.135.861 or http://www.zip-products.com/Zip/prod...3EAEB5513144BB
This is what I used!
Thanks,Matt
Old Jul 29, 2006 | 09:19 PM
mseven's Avatar
mseven
Because of the intake, I have done the same with no problems.
With what you have done to the car you will probably be doing some datalogging and fine tuning anyways.
Old Jul 30, 2006 | 12:13 AM
Sam Lam's Avatar
Sam Lam
I have moved the IAT sensor on my 89 from under the plenum to the front air intake. I cannot see any performance gain from the aftermarket kit. However, the new location makes servicing the IAT much easier. If you want a photo, let me know.
To Intake Air Temp sensor?
