SeaFoam Carbon Remover
Old Sep 5, 2001 | 10:24 AM
olephart's Avatar
olephart
Default SeaFoam Carbon Remover
This stuff seems to be real popular on the z28 forum. I'm thinking about using the spray version on the throttle body and intake area.
Any one use it? Any downside? Most of all, does it work?
Old Sep 5, 2001 | 02:02 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Re: SeaFoam Carbon Remover (olephart)
I used it on the 84 and it worked great.
Old Sep 5, 2001 | 02:09 PM
Tom Piper's Avatar
Tom Piper
I have read that the throttle body plates have a coating on them that some chemical cleaners can remove. This coating is supposed to retard deposits. Unfortunately, I don't know which chemicals are safe. In addition, you can scrub the coating of with some abrasive pads.
Tom Piper
Old Sep 5, 2001 | 06:24 PM
vettenuts's Avatar
vettenuts
Default Re: SeaFoam Carbon Remover (Tom Piper)
If it is throttle body safe it should say that on the can. However, you state that it is a carbon remover, do you mean carbon on the top of the cylinder? How about GM top engine cleaner?
Old Sep 5, 2001 | 07:41 PM
olephart's Avatar
olephart
Default Re: SeaFoam Carbon Remover (vettenuts)
Well, they say it is very similar to the GM Top Engine Cleaner, but cheaper. It comes in liquid or spray. The z28 guys put a can in the fuel and 1/2 can in the oil. Then they allow a vacuum line to suck the liquid into the intake area 'till the engine stalls. Some use the spray instead of the liquid in the intake.
They leave it for 15 minutes then start the engine and engulf the neighborhood in smoke for about 5 minutes. It's supposed to clean the carbon out of the intake and valves. They claim amazing results.
That's all I know about it. Don't know if it's TB safe. Just wondering if it's worth the trouble.
Old Sep 6, 2001 | 02:04 AM
TPFKATK's Avatar
TPFKATK
My son works at NAPA. He has customers who buy it by the case for resale at car shows. The user comments he gets make this stuff sound like the greatest thing since sex.
To SeaFoam Carbon Remover
