Ok here we go.....
Plug wires? which ones should I get? should I order them internet or get them from local parts store like Discount auto?or at the dealer?
on the to do list is:
oil,fuel filter,hoses,belt,plugs,tranny fluid change and rear end fluid change, radiator flush.......
any tips before I get started?
Before you get too deep, go to www.helminc.com and order the Factory Service Manual for your car. This is the same set of books the GM techs use and they are worth their weight in gold when it comes to working on the C4. Other sources are the C4 Parts For Sale section or eBay.
Don't bother with the $10 Haynes or Chilton's books; they are garbage.
How many miles are on the car? I wouldn't bother with wires at this time unless there are signs of the insulation cracking or areas where heat has burned the insulation. Wires and plugs are not real easy to do and any wire larger than stock will require modding the wire retainers.
Finding the correct belt may be an issue. In the middle of the 93 model run, GM changed the belt from a two-sided version to a single side. Which one do you have? If it's the 2-sided version, get a belt from the dealer or one of the Forum Supporting Vendors like Fred Beans Chevrolet or Ken Fichtner Chevrolet. If the belt is single-sided, you should be able to find a belt at a NAPA or CarQuest store. Dealer is also an option.
I installed MSD 8.5 SuperConductor wires in my 92 and it took a good 3 hours to do with removing or shoving aside most of the accessories to get to the Opti so I could release the wires. I did plugs (NGK Iridiums) at the same time. I removed the center and rear lower fender lines to access the plugs but #6 and 8 is a real PITA anyway.
A complete radiator flush involves removing the 2 knock sensors at the bottom of the block to drain all the old coolant. Not hard, just messy and you need a 22mm socket to remove them. Use a 50-50 mix of green coolant and distilled water. There are two bleed valves that must be opened to "burp" the system of air. One is on the top of the t-stat housing and the other is on the lower front drivers side of the throttle body. DO NOT let any coolant run down over the Opti!!
There are lots of neat Tech Tips for C4''s available. Go to the "OTHER" button at the top of the page, select Tech Tips and then C4.
As to wires, I'm not sure. I'd replace them if you've got miles on the car and they're carbon core which breaks down beneath the surface.
Green coolant only for pre-'95, orange for later years. Note from what I understand, thermostat is unique to Corvette if you decide to replace. And not only no coolant over the Opti, no water at all.
Give us some more info on the car like what's been done, or what you think's been done.
I recommend the OEM AC Delco wires for a stock engine. They are high quailty, and are the exact length to fit perfectly, and will also fit correctly into the wire looms without breaking them. Larger diameter wires can be problematic with the looms. Contact Chris May at Superior Chevrolet (1-800-728-8267) for OEM wires at a great price. Be sure to tell him you're a Forum member.
Be well,
SJW
from looking over the car wires look ok,hoses upper radiator definitely need replacing as they are swollen when hot.....
belt is double sided so will get that from the dealer as it has some cracks in it...
fuel filter was never changed by previous owner and brakes are a little low for me still some meat on the pads but not enough for me...
P.S. profile updated
May also want to drain and replace brake fluid as well as pads if you don't like the way they look. Fuel filter, now. Do PS, too. Differential, maybe?
