Difference between 85 and 86 Exhaust?
Old Aug 1, 2006 | 08:34 PM
TucksC3's Avatar
TucksC3
Default Difference between 85 and 86 Exhaust?
There's a magnaflow exhaust for sale on the forum for n 86. I'm interested in it but I have a 85. What would it take to make it fit? Large scale operation or just a little garage engineering? Thanks in advance for the info. I know someone around here has done this probably a couple dozen times.
Old Aug 1, 2006 | 08:43 PM
mikey whipreck's Avatar
mikey whipreck
The cat connection is completely different.
You'd need an 86-91 front Y pipe, an 86-91 cat... then you could fit that magnaflow system.
Old Aug 1, 2006 | 09:02 PM
Electricblue80's Avatar
Electricblue80
I took a look at the exhaust in question. It should work and I'm sure a muffler shop could fabricate it on for you. Do a little research on the web at at popular corvette item sites. You might find the right answer.
Old Aug 1, 2006 | 09:31 PM
vader86's Avatar
vader86
An exhaust shop should be able to weld it right up for you, but the difference is the main cat.
One is slip-fit, other is bolt-in.
Old Aug 2, 2006 | 01:12 AM
TucksC3's Avatar
TucksC3
As always, you all are a wealth of information. I appreciate it.
Old Aug 2, 2006 | 06:24 PM
Fasterer's Avatar
Fasterer
My 85 has a 4 bolt flange to the cat. The 86's have a bell end to the cat with slip flange.
Bill
To Difference between 85 and 86 Exhaust?
