spun bearing
Old Aug 3, 2006 | 07:26 PM
squalsvette's Avatar
squalsvette
Default spun bearing
Hey fellas...... i was just reading a post about a guy over heading all the time, and one of the replys were if your oil temp. is hotter than your coolant temp. then you spun a bearing. my coolant is 200-210 and my oil temp is around 230 all day. 230 is no problem for the synthetic right? Is there any truth about that bearing crap. Stay cool everybody
Old Aug 3, 2006 | 07:44 PM
CFI-EFI's Avatar
CFI-EFI
After it warms up, it is normal for the oil to run hotter than the water temp, especially without the factory oil heater. My coolant is usually lower than yours but my oil runs about the same. I use dino oil.
RACE ON!!!
Old Aug 3, 2006 | 10:52 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
If you spin a bearing, your temp will go way higher than 230. That's a perfectly normal oil temp w/o an oil cooler.
Old Aug 4, 2006 | 12:20 AM
cv67's Avatar
cv67
St. Jude Donor '05
what they said. You spin a bearing, you'll know it!
Old Aug 4, 2006 | 07:56 AM
chucks88's Avatar
chucks88
Originally Posted by CFI-EFI
....without the factory oil heater.
Cooler?
Old Aug 4, 2006 | 09:45 AM
redrose's Avatar
redrose
Originally Posted by chucks88
Cooler?
here we go again...yes, its a cooler--''normal'' operation is for oil temp to be 10-30* above the water temp, so it can only function as a cooler in that situation....and it is there to reduce oil breakdown at elevated temps
now stand back and smile at the obtuse theories that will be expounded about ''warming cold oil for ???? reasons.
Old Aug 4, 2006 | 02:48 PM
squalsvette
what?
Old Aug 4, 2006 | 04:30 PM
CFI-EFI's Avatar
CFI-EFI
Cooler?
I said "heater" with tongue in cheek, but in reality, they are plumbed just like my heater. In practice, the heat will be transfered from the warmer fluid to the cooler fluid. During warm up it's a heater, after the oil temp surpasses the water temp. it's a cooler.
RACE ON!!!
To spun bearing
