Timing Chain
Old Aug 4, 2006 | 10:08 AM
jodyeastman's Avatar
jodyeastman
Default Timing Chain
I am interested in upgrading my timing chain when I do my heads ,etc. Can anyone recommend what timimg chain and the best place to get it? I looked on Summit and there are a few different models and I'm not sure which one I need.
1994 LT1 automatic. Thanks guys.
Old Aug 4, 2006 | 10:50 AM
rickneworleansla's Avatar
rickneworleansla
http://forums.corvetteforum.com/show...ghlight=coyles
Old Aug 4, 2006 | 12:39 PM
STL94LT1's Avatar
STL94LT1
From what I've seen your only options are: Buy a new stock timing set, Lunati makes an aftermarket set, or upgrade to the Cloyes double roller. But, to run the Cloyes you'll need to upgrade you opti, timing cover, opti wire harness, opti vacuum harness, and camshaft's dowel oin.
Oh forgot, with the Cloyes you need to run an electric water pump.
Old Aug 5, 2006 | 12:00 PM
jodyeastman
Hey thanks guys
Old Aug 5, 2006 | 09:45 PM
comp94's Avatar
comp94
cloyes makes a replacement chain for your engine that is slightly better than stock but it is big money. If i had it too do all over again i would do the newer style opti swap because you can run a double roller timing chain. Also when you go to take off the hub on the crank there is a special removal/installation toll that kent more makes for the LT-1. Even with this tool the hub is a PIA to take off and install. Good luck
Old Aug 8, 2006 | 10:12 AM
jodyeastman
Just curious but with the Danaspark opti, can a double chain be run?
Old Aug 8, 2006 | 11:27 AM
RCFguitars's Avatar
RCFguitars
Yes, I have the Dynaspark and the Cloyes, and I could not be more pleased.
Old Aug 8, 2006 | 12:42 PM
STL94LT1's Avatar
STL94LT1
Yes, but you'll have to upgrade to the 95/96 opti, 95 timing cover, 95/95 opti wire/vacuum harnesses, change camshafts or change your current camshaft's dowel pin, and an electric water pump.
Old Aug 24, 2006 | 09:56 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I'm doing sort of a same job. I need to replace the timing cover seal and O ring. To re-install the HUB, how is it done?
To Timing Chain
