Alternator Advice
Old Aug 5, 2006 | 01:56 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Originally Posted by Ironcross
Yep,
All remanufactured and new products by operation of law carry a warrantee. The only items not recoverable are normally on used products and those not sold in the stream of a commercial operation. It`s that lifetime warrantee products are a roll of the dice as to quality and normally a high profit product for the seller.
I spent over 25 years in the electronics industry and I can tell you you are just wrong. The only thing that makes lifetime warranties work is a consumer with no follow through.
Old Aug 5, 2006 | 02:19 PM
Ironcross's Avatar
Ironcross
No I`m not. I sell electronics, and damn good ones with nearly zero return with the quality built in. It`s the high profit low cost products that justifys the lifetime warrantee for a unspecting sucker. Otherwise they would be out of business as you cannot continue to give products away. Does your Vette have a lifetime warantee?
Old Aug 5, 2006 | 02:27 PM
BADDUCK's Avatar
BADDUCK
So back to my original recommendation of the Duralast Gold alternator. $120 exchange for a NEW alternator with lifetime replacement warranty. Tell me exactly WHERE the ripoff is!
Old Aug 5, 2006 | 02:39 PM
Ironcross's Avatar
Ironcross
I just called, 69 Riviera, "new" $169.95 + $20.00 core charge. Since when does new products require a $20.00 core charge? Only remans require exchanges. Is it that they can also make money on cores?
Old Aug 5, 2006 | 02:44 PM
BADDUCK's Avatar
BADDUCK
O. K. so I guess your approach to the tech board is to try and "shoot down" other peoples recommendations. So far all you have done is pontificate. What is your solution, or maybe you are lost and think this is the general board.
Old Aug 5, 2006 | 02:52 PM
BADDUCK's Avatar
BADDUCK
What has a '69 Riviera have to do with anything. We are talking about Trixie's Corvette right? Good Grief!
Old Aug 5, 2006 | 02:56 PM
honda hunter's Avatar
honda hunter
Originally Posted by TheCorvetteKid
These are the guys I just bought my new alternator from. I went with a 160amp unit instead of the 200amp. When I spoke to the guys at Motor City Reman, they said the 160amp is far better for street use than the 200amp version (doesn't put out enough voltage at low RPM).
The only hang-up is that you have to upgrade the postive cable going to the alternator to the distrubution block - they suggest 4 gauge wire.
Good luck!
Good info. I didnt know that.
Old Aug 5, 2006 | 03:35 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
If you contact Motor City Remans you will find they sell a LOT of new units. You have to check the application.
I recently bought a NEW 105 amp alternator for my 93 Grand Prix. Works better than any other alternator I have ever had. And my 3.4L V-6 is notorious for over heating the alternator because of the placement of the unit on the engine.
