Nitrous Experts Help Needed
Dana 44 with 3.73's
2200 stahl
Headers
FLowmaster 40 series
cut lid @ K.N. filter
Air foil
mild cam
I want to add a 100 shot dry system and I have many questions
If I buy the Zex kit with the digital controller what else do I need ?
I want to do this however I want to make sure I do it right the first time. I also want to make sure I have enough money to pay for everything. I was thinking of buying the Zex kit and a bottle heater, purge kit and an A pilar guage pod for fuel pressure and nitrous. What am I forgetting ? How much should this whole thing cost ? I am planning on doing the install myself. My car is in excellent running condition and has all new plugs, wires, coil, opti, waterpump new fluids and filters. Your advice would be appreciated. Another question I have
is how do you use your nitrous ? I can't use anymore power from a dig
so just spray it through second and third gear I guess ? How does that work though ? I thought the nitrous was on at W.O.T. ?? What do you do arm the system just before use or can you spray it manually ? Thanks, John
Here's a long write up I did on the bottle, and a bit about installing it in a 91:
http://temp.corvetteforum.net/c4/vader86/nitrous.html
Let us know what you come up with!
I would appreciate your opinions on this kit greatly.
Great write up on nitrous, good reading and answered alot of questions
this post. That kit does look very appealing to me as well. One thing I believe you will need is a safety blow off tube and according to their instructions, bigger injectors, and I would assume either a tune for it or boost retard of some type. (says to use stock chip if you have a modified chip) It appears it is designed more for a stock engine but will work on a modified engine with the above changes, ie, tuning, and injectors.
Good luck
Edit: I just noticed you have a chip instead of an EPROM. You should be able to replace it with a custom N2O programmed chip or use the stock chip with the MSD box. I believe there may also be a setup that lets you reprogram the chip on the fly. Not 100% sure. Check out moates.net or email one of the forum tuners.
Here is a shot of the intake with the nozzle installed in the smooth air duct.
Down there is the management box. It is strapped down to the front cross frame rail.
There is a shot of the management unit and the purge solenoid.
Here is a picture of the bottle mounted in the convertible hatch area. I actually still have room for my 8" bass tube if I wanted to leave it in. I also have a black velvet bag that covers the bottle, it looks real good. I am not a big fan of bright purple.
The bottle warmer is not in there yet. Maybe this weekend. I got the one that connects to a 12V source. They have a different one that will go to the cigarette lighter but I don't like visible wires hanging around.
Here you can see the blow down tube that exits the car through the floor. I also have the PSI gauge but it's pointed the wrong direction to see from the drivers seat, and it's too dark at night. A pillar gauge will be in there soon.
The activation switch is mounted here. I'm going to make a custom plate that will mount to the left of the center console shown here. It will be where the carpet meets the plastic, by the drivers right leg. Any other suggestions are welcome.
There is the red purge button, to the left of the alarm button.
The nozzle and 125hp jet was installed here.
1) why a dry kit and the cost of injectors when a wet kit is a minimal amount more $$ without needing injectors?
2)what HP shot are you running? oops nevermind I just saw a 125hp nozzle mentioned.
I agree with a majority of your advice and appreciate the time to post the pics as I'm sure the original thread creator does as well.
I see you are still running the stock MAF w/ screens. Are you planning to upgrade it? I don't really think you need to but was curious if you had looked into it. You've got all the O2 you need from the spray
See the picture of my MAF screen here and explaination.
http://forums.corvetteforum.com/show....php?t=1471802
http://forums.corvetteforum.com/show....php?t=1474396
My personal opinion is to use a wet system as any "hiccup" with the injector pulse width, you stand to have a major problem, especially with a shot over 100 on a dry system. The only real "problem" with wet kits is they can go overrich, but that won't cause a nitrous backfire...it'll just slow you down a bit. Dry kits can go too lean, and in simple layman's terms, "That's bad"
There are others, of course who've had no problems with dry shots, but do your research first before deciding.
YMMV
http://forums.corvetteforum.com/show...rous+explosion
