1989 Error Codes ?
Old Aug 5, 2006 | 10:47 AM
Clark Bente's Avatar
Clark Bente
Default 1989 Error Codes ?
Hi
Anyone have a list of error codes for my stock '89 L-98 6sp?
30k miles, runs great.
I just got a 3-6 code, but it's not in my book. Cleared it, it was gone for a few days, now it's back.
Help! Thanks.
Old Aug 5, 2006 | 10:56 AM
RRT vette's Avatar
RRT vette
I don't have my FSM or any refrence right now but a code 36 has to do with the MAF. Someone will help until I can get to my book.
Old Aug 5, 2006 | 11:45 AM
Clark Bente
Default Thanks
Thanks. Mine is white, too.
Old Aug 5, 2006 | 11:49 AM
CFI-EFI's Avatar
CFI-EFI
It sounds like it's time for a new book. The proper year FSM will not only list the sources of all the codes, but also a trouble shooting chart for each code to keep you from wasting money replacing good parts.
RACE ON!!!
Old Aug 5, 2006 | 12:22 PM
rick lambert's Avatar
rick lambert
Code 36 is the MAF burnoff circuit, If you're lucky it's the relay, you have 2 relays, MAF burnoff and MAF power, about 10-15 bucks each, replace both. If you had the FSMs CFI-EFI suggested you could trouble shoot the entire code 36, wires and all.
Old Aug 5, 2006 | 02:24 PM
Clark Bente
Thanks Rick and CFI-EFI
If I remember correctly, they're on the inner fender, near the battery. My car's been running good for a couple of years, and I haven't had to do any repairs (summers only - low miles). I had to replace a relay in that area a couple of years ago. I forgot what for, but I'll check the entire circuit, starting with the wires and connectors, and end with the relays. If that doesn't do it, I'll replace the MAF.
Running ok w/ the error code made me guess that it's in "safe" mode, and that's probably why it seems to run acceptably.
Old Aug 5, 2006 | 02:32 PM
RRT vette's Avatar
RRT vette
Do you have a FSM? It is much cheaper than a new MAF and will show you exactly what the problem is from the troubleshooting steps. If you don't have the manual...I will try and lead you step by step from my 86 manual (should be about the same). BTW, if you contact Agent86, he has the codes out of his manual and will post it for you.
Old Aug 5, 2006 | 04:50 PM
86PACER's Avatar
86PACER
http://members.shaw.ca/corvette86/Code%2036.pdf
Old Aug 5, 2006 | 04:58 PM
RRT vette's Avatar
RRT vette
There you go. 86Pacer came through for you. Should all be down hill from there.
Old Aug 5, 2006 | 05:11 PM
86PACER's Avatar
86PACER
Actually Agent 86 did the work. He has all the codes on PDF here:
Old Aug 5, 2006 | 05:20 PM
Clark Bente
Thanks RRT and 86Pacer.
I'll be on it tomorrow afternoon. My idea of a perfect Sunday - under the hood of my Corvette, chasing a problem that's not too hard and is easy to get at.
Thanks again for really coming through with the pdf of the FSM.
To 1989 Error Codes ?
