Lisle 12 pc. Torx Bit Set
Old Aug 7, 2006 | 08:23 PM
bogus's Avatar
bogus
Originally Posted by 92Beast
How about scanning us the add so we an take it in to Sears and get the $16.50 pricing since most of use will have pitched the ad by now.
I doubt it's a coupon... Sears doesn't normally work that way.
Old Aug 7, 2006 | 08:26 PM
bogus's Avatar
bogus
Originally Posted by CFI-EFI
Like in my response to 92Beast?
A rare moment of lucidity.
Why is that "beyond laughable"? What do YOU call someone that makes a post for no good reason that contains nothing but false information?
RACE ON!!!
I call my post made for a good reason. Is it my fault the damned book apparently has an error?
Said error I was not aware of? You make it sound like I made that post intentionally; just to mislead people. Talk about bull****.
Old Aug 7, 2006 | 08:42 PM
CFI-EFI's Avatar
CFI-EFI
You KNOW that is baloney.
There was no reason for the post in the first place. You only created disruption and dissension where there had been none. It is not your fault the book is misprinted, but it is your fault that you cared to compound the error by posting, that of which you have no knowledge.
"bull****"! That is the word for it. You do do a lot of that. Far be it from me to second guess your motives.
RACE ON!!!
Old Aug 7, 2006 | 08:49 PM
bogus's Avatar
bogus
Yea, right...
WTF? Are you smoking crack? You are telling me that I was supposed to know that the book was wrong, and that by quoting the book, I am somehow perpetuating the problem? That is the most insane thing I have ever read.
You preach to follow the book. I do, and now that's not good enough? I not only have to know the book, I have to know all of the ****ing corrections? Now THAT is bull****.
There was no dessention. And my post only has caused a problem between me and you, as usual. You just can't comment and move on, NO, you have to dig and dig and dig. You so revel in finding error. And then rub peoples noses in it - and you seem to genuinely enjoy doing it to me.
All you had to do was quote my statement, and say, "Wrong answer, there was a typo in the book, it's really a T55."
Which I would have replied, "Oh, that's interesting, I didn't realize that."
But no, you have to put me on the defensive, causing this thread to go to ****, and have the ***** to blame me for it.
You are one messed up individual.
Old Aug 7, 2006 | 08:56 PM
wayne lowry's Avatar
wayne lowry
Lisle torx bits are guaranteed forever. I do not know if Sears will warranty them though. You might have to send them back to Lisle.
Race On!!! A 13 second car If I had a Crossfire I'd be too
Old Aug 7, 2006 | 10:55 PM
Plasticman's Avatar
Plasticman
Guys, think the sale ended on the 5th. I did order a set that date, but then checked my manual today, since I need to replace my 2 rear hubs, and see what else I might need when I saw the mention of the T-45 Torx listed.
I can understand the confusion! On another thread I saw a mention of replacing a teflon coated washer to prevent clicking (after replacing the hubs). In my parts manuals (both on CD and an actual GM parts manual), I see that the washer is not listed under the early Vettes up to and including 87 (my C4 is an 87). However, the 87 service manual shows the washer! So I guess I need these washers after all.
Sorry for causing the ruckus. Just trying to get to the bottom of some questions, and I know you guys are always a great help (as I hope I am to some small degree on the C1/C2 forum).
Plasticman
Old Aug 7, 2006 | 11:03 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Ok... back to the torx bits here...
An alternative to the Cman and Lisle offerings are a set by OTC. I have them and they seem to put up with my abuse just fine. Made in th USA too. You can check them out here, or see if your tool store carries them:
http://www.thetoolwarehouse.net/shop/OTC-6100.html
Old Aug 8, 2006 | 12:28 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Take the fighting to email please. No more hijacking either.
Old Aug 8, 2006 | 02:48 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I broke every torx set I had,well not the entire contents but at least one or two pieces broke or twisted.My snap on torx set,the t45 and T 55 broke off at the tip.My sears set,from years ago,all twisted sideways.Junk!
Wasnt the lisle brand but the crafts-break kind.
I bought the 4 pack large chinese set from advance auto,long silver torx bits,forget the name of the toll brand/part,held up fine for a long time but then one day broke the T55 off.
Even the solid black ones I had bought from an local parts store in the package alone that said heat treated broke off at a tip and one shattered.
Most of these happened when some of the dang bolts would not come off without a breaker bar on it.Seat belt torx bolts are the worst to break free on 15+ year old cars.Torx and I arent friends!
I learned to clean the torx hole stars in the bolts with brake kleen first,then make sure the tool is firmly seated all the way in,and avoid pulling/pushing sideways on install or removal.Was a big reason I broke a few but the others were just not made very well in materials.
Old Aug 8, 2006 | 06:19 AM
Joe C's Avatar
Joe C
in my 85 FSM, one section, on removing the emergency brake assembly indicates using a t45 and another section, on removing the bearing/hub assembly indicates using a t55. ...and t55 is the winner - when i started the job of replacing my bearings, i stuck a t45 in the torx bolt. right away, i knew it was too loose, and something was not right. i then went to a t50, a little better, but not right. i didn't have a t55, and the only place open was the local hardware store. i bought a stanley t55 for $4.00 - worked great - no failures, and even used an impact wrench for removable. installed by hand and torqued to 65# (as i remember). i think the t45 as stated might be a typo...
