Passing Emission Test Question
Old Aug 5, 2006 | 01:35 PM
RED92LT1's Avatar
RED92LT1
Default Passing Emission Test Question
I'm going to be moving to a part of Pennsylvania that does tailpipe emission testing. Will my 92 pass without catalytic converters? The shells are there but the previous owner gutted the cats.
The car is stock except for a Hypertech chip, cool thermostat and flowmaster exhaust system.
What are my chances of passing or what do I have to do short of replacing the cats to pass the "sniffer" test?
Thanks in advance for your help an advice.
Brian
Old Aug 5, 2006 | 06:16 PM
Perfusion's Avatar
Perfusion
Brian
Highly doubtful... Not impossible - just improbable. Get an inexpensive set of aftermarket cats (or even better, find a used OEM set here on the forum for sale), and be done with it. If PA is like CA, when the car fails emissions, it's reported to the state and ends up on your car's CARFAX report, and in CA at least, causes you more trouble down the road when it's time to smog again.
Best of luck...
Old Aug 5, 2006 | 07:04 PM
SunCr's Avatar
SunCr
If you can pass without Cat(s), let the OEM's know - Bill Gates will be jealous of your wealth. Otherwise, hope no one goes here:
http://www.epa.gov/compliance/complaints/index.html
Old Aug 5, 2006 | 08:49 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Heh, heh, I think you've used that one before! And it's funny because it's sooooo true!
Old Aug 5, 2006 | 11:04 PM
Thrak's Avatar
Thrak
depending on how high their allowable are, you have no chance of passing w/o cats...
read my 1st post, and last post, here to see how much a cat affects emissions on a car that is running near perfect.
http://forums.corvetteforum.com/show....php?t=1457620
Old Aug 5, 2006 | 11:21 PM
RED92LT1's Avatar
RED92LT1
You're not a tree hugger are you?
Old Aug 6, 2006 | 02:27 AM
steve1ph2's Avatar
steve1ph2
"If you are experiencing an environmental emergency or are witnessing an environmental event that may lead to imminent loss of life, select the emergency link at the right". i hardley think a gutted cat or two applies.
Old Aug 6, 2006 | 10:52 AM
RED92LT1's Avatar
RED92LT1
Thanks for putting this in perspective. I was tossing and turning all night thinking the EPA would be knocking my door down in the morning.
On a more realistic note thanks (Perfusion) for the useful advice, I did find a set of direct replacement cats at Summit Racing for $166 per side.
And I hope the EPA knows I'm "just kidding" I wouldn't do anything to increase "Global Warming" or kill a tree!
Thanks Again from somewhere on the Right Coast!
Brian
Old Aug 6, 2006 | 11:02 AM
zr1fred's Avatar
zr1fred
Do you have the link for the cats or Summit Racing? thanks
Old Aug 6, 2006 | 11:57 AM
george4's Avatar
george4
http://www.summitracing.com/
Old Aug 6, 2006 | 12:44 PM
bogus's Avatar
bogus
This is not so much about killing a tree, it's about messing up the air we have to breathe....
I don't believe the emissions from cars, when properly controlled, really have a hugely negative impact on our collective air quality. But, when not controlled, does have a huge impact on the ground air we breathe, and, an equally negative impact on the overall environment.
Case in point, California researchers have found airborne pollutants intermixed with the local air... FROM FACTORIES IN CHINA.
From my perspective, if we as drivers and responsible enthusiasts do our part by keeping our cars clean, we can do wonders to help the air we have to breathe and that of our children, and their children.
If we don't, I could see just about every hot rod engine trick ultimately outlawed. And I would blame every one of you who doesn't believe in even a small amount of responsibility for it.
We have seen that corporations can build factory hot rods with huge power, yet maintain emissions compliance. It isn't impossible for us, either.
To me, it isn't worth it to build that 650hp monster machine if it's going to pollute so much, and stink up the air around me that it makes my eyes water. I would rather have a more streetable 450hp machine that will burn clean and still run like a raped ape... and not stink up the joint.
Save that killer car for a race track somewhere.
My wife and her family grew up in greater Los Angeles. Her mom grew up in downtown LA, near the Coliseum back in the mid-1960s. Thanks to the unique geographical (and geological) conditions in the basin, the air quality was horrid. She remembers as a teenager walking to the bus, and her lungs burning from the smog.
This is not good for anyone. And if you want to experience this, just take a trip to parts of Mexico, India, China or Russia. Knock yourself out...
And consider yourself lucky we live in a society that has enough wealth and common sense to do something about it.
Old Aug 6, 2006 | 12:53 PM
toptechx6's Avatar
toptechx6
Well said bogus! I've lived in areas with and without emission testing and can clearly see the standards have a positive impact, it may take time but if we don't try to improve air quality our grandchildren may not ever experience the joy our cars can provide.
Old Aug 6, 2006 | 01:02 PM
RED92LT1's Avatar
RED92LT1
This is the link to Summit's online catalog with the direct fit cats.
Brian
http://store.summitracing.com/egnsea...=KeywordSearch
Old Aug 6, 2006 | 02:59 PM
SunCr's Avatar
SunCr
Ever flown across the US in the summer and watched the sky turn brown somewhere before the Mississippi?
Old Aug 6, 2006 | 05:17 PM
toptechx6's Avatar
toptechx6
Sorry but I had to smile over that one
I expect you mean flying east and I always find it scarier flying into San Diego or LA!
No matter, seems we both realize the air needs improvement, and that is the important part.
Like LA Florida has some unique geography that has an influence, only here because we a peninsula the constant air movement improves our air quality. Consequently the EPA gives us good ratings that allows NO emission testing in the state. I know I'll take some flames for this but I believe that is a mistake, there are more junk cars polluting here than up north in the rust belt industrial areas! Even if Florida air tests good no doubt we're killing some poor guy in a third world country. Another factor that makes testing so hard to swallow for many is inconsistancy of testing across the country, to me that should be standardized rather than the patchwork mess in use now.
I'll put on the Nomex now and wait!
Old Aug 6, 2006 | 05:26 PM
mikey whipreck's Avatar
mikey whipreck
What county in PA uses a sniffer?
Odd...
Old Aug 6, 2006 | 06:29 PM
RED92LT1's Avatar
RED92LT1
Odd...
Check this PDF out, Philadelphia and Pittsburgh are on the sniffer list ... and vehicles driven under 5000 miles annually can be exempted.
http://www.drivecleanpa.state.pa.us/...e/brochure.pdf
Sorry guys ... pardon the pun but I didn't mean to make a big stink over this. I just wanted a little advise not a lecture.
Brian
To Passing Emission Test Question
Old Aug 7, 2006 | 10:41 AM
mikey whipreck
Brian
I asked that because I passed my PA emmisions with a hollow cat and AIR pump.
I didnt know the big cities did that.
Old Aug 7, 2006 | 11:11 AM
TA's Avatar
TA
Under 5K miles and you're exempt, but what that brochure dosn't mention is that the vehicle is still subject to a visual test, so if you don't have cats you will still fail.
Old Aug 7, 2006 | 11:40 AM
Fasterer's Avatar
Fasterer
My 2 cents on this. I to grew up in the hot rod hey days and also saw the dreaded pollution, however all the sniffing and testing on our cars is a joke. I'd like to see real testing. No real converters that work. Tell me how someone could be coughing on car tail pipes in the past and can breath what comes out of them today. How many of you are at stop light, toll booths etc and CAN NOT BREATH because of the acid being spewed out. Im sure we are improving one type of pollution but are we going off in a whole other direction. Do a littmus test on tail pipe emissions a you decide. We still have a ways to go.
