water temp sender/connector
Old Aug 6, 2006 | 01:43 PM
Jim D's Avatar
Jim D
Default water temp sender/connector
While I was installing new plugs , the temp sending unit connector crumbled in my hand. It looks like a unique conn. end. Can I buy this or is there a mod I can do, thanks Jim.
Old Aug 6, 2006 | 01:49 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Ecklers has a replacement connector for $4.99. Dealer may have it and save shipping.
Old Aug 6, 2006 | 02:10 PM
Jim D's Avatar
Jim D
Do you have the part # for Ecklers, thanks Jim.
Old Aug 6, 2006 | 02:28 PM
BADDUCK's Avatar
BADDUCK
30550 1985-95 Coolant Temp. black $4.99
Old Aug 6, 2006 | 02:34 PM
Aardwolf's Avatar
Aardwolf
You could solder it to.
Old Aug 6, 2006 | 02:40 PM
RRT vette's Avatar
RRT vette
I think that connector is for the CTS on the front of the intake manifold. You can get a female speaker terminal connector the same size as the tooth and you should be able to crimp it to the wire and connect it....or solder it as mentioned.
To water temp sender/connector
